WMS and SRS issue: "Invalid SRS given : SRS must be valid for all
requested layers."
Marcos Cobeña
marcoscobena at GMAIL.COM
Thu Jun 22 03:52:59 EDT 2006
Hi all,
I'm trying to access to a layer made of SHP files, like this one:
# DGIS_12c.map
MAP
NAME DGIS
STATUS ON
SIZE 800 475
# "Huelva, Spain " lat=37.258335, lon=-6.9508333
EXTENT -180 -90 180 90 # 187889.12817030 4092316.51133811
197493.65136571 4099997.10096501 # 36.258335 -7.9508333 38.258335
-5.9508333
UNITS METERS
SHAPEPATH "Data"
IMAGECOLOR 255 255 255
IMAGETYPE PNG
CONFIG "PROJ_LIB" "C:\Archivos de programa\Apache Software
Foundation\Apache2.2\cgi-bin\DGIS\Data\Proj" # "C:\Documents and
Settings\Marcos\Escritorio\Temporal\Sistema de Información Geográfica
de Doñana (DGIS)\ms4w_2.0\ms4w\proj\nad"
WEB
METADATA
"wms_title" "Sistema de Información Geográfica de Doñana (DGIS)"
# http://localhost:8080/cgi-bin/DGIS/mapserv.exe?map=DGIS_12c.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetCapabilities
"wms_onlineresource"
"http://localhost:8080/cgi-bin/DGIS/mapserv.exe?map=DGIS_12c.map&"
# "wms_srs" "epsg:4326" # "EPSG:4269 EPSG:4326"
END
END
PROJECTION
"init=EPSG:42304"
END
LAYER
NAME "12c_linea"
TYPE LINE
STATUS ON
DATA Data/12c/12c_linea
CLASS
NAME "12c_linea"
COLOR 0 0 0
END
METADATA
"wms_title" "12c_linea"
"wms_srs" "EPSG:4326" # "EPSG:4031"
"wms_format" "image/png"
END
END
END
, where I've defined a projection ("init=EPSG:42304") and, for each
layer, its own SRS ("EPSG:4326"). It works fine, it draws my shape in
Canada (as expected with projections used).
Once I change main projection to 4030:
# Unknown datum based upon the WGS 84 ellipsoid
<4030> +proj=longlat +ellps=WGS84 +no_defs no_defs <>
, the one used in ArcView when shapes were created, I receive those errors:
msWMSLoadGetMapParams(): Invalid SRS given : SRS must be valid for all
requested layers.
I've checked if projection file was been found or not, but it was.
Does anyone know any hint?
Thanks in advance.
Regards,
Marcos - http://www.youcannoteatbits.org
