msWMSLoadGetParams
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Jun 23 06:57:57 EDT 2006
Please note you need to use lowercase epsg in PROJECTION blocks. At
least on Linux this is case-sensitive.
Best regards,
Bart
Marcos Cobeña wrote:
> Hi Alexander,
> I think you should use PROJECTION tag to define projection used in
> your different layers. Something like:
> PROJECTION
> "init=EPSG:4031"
> END
> We'll be waiting for your feedback, good luck!
> Regards,
> 2006/6/22, Alexander Rodríguez Torres <atorres at estudiantes.uci.cu>:
>> I receive this error when I try load my map
>> msWMSLoadGetMapParams():Invalid SRS given:SRS must be valid for all
>> request layers
>> Somebody can help me????
>> This is my .map
>> MAP
>> NAME "Mapa de la UCI"
>> STATUS ON
>> EXTENT 9387137.4 805683.77 10119140.81 1507910.77
>> SIZE 500 500
>> SHAPEPATH "/var/www/localhost/htdocs/MapaPost/data"
>> SYMBOLSET "/var/www/localhost/htdocs/MapaPost/etc/symbols.sym"
>> FONTSET "/var/www/localhost/htdocs/MapaPost/etc/fonts.txt"
>> IMAGETYPE PNG
>> IMAGECOLOR 174 183 207
>> UNITS METERS
>> TEMPLATEPATTERN "UCI"
>> WEB
>> MINSCALE 259371
>> IMAGEPATH "/temp/"
>> TEMPLATE mapa.html
>> HEADER mapa_header.html
>> IMAGEURL "/temp/"
>> END
>> REFERENCE
>> STATUS ON
>> IMAGE "/var/www/localhost/htdocs/MapaPost/images/keymap.png"
>> SIZE 88 69
>> COLOR -1 -1 -1
>> OUTLINECOLOR 255 0 0
>> MINBOXSIZE 3
>> MAXBOXSIZE 0
>> MARKER 0
>> MARKERSIZE 0
>> END
>> QUERYMAP
>> STATUS OFF
>> SIZE -1 -1
>> COLOR 255 0 0
>> STYLE HILITE
>> END
>> # Start of legend object
>> LEGEND
>> STATUS ON
>> IMAGECOLOR 255 255 255
>> POSITION LL
>> KEYSIZE 18 12
>> KEYSPACING 5 5
>> TEMPLATE "ttt"
>> LABEL
>> TYPE BITMAP
>> SIZE MEDIUM
>> OFFSET 0 0
>> BUFFER 0
>> MINDISTANCE -1
>> MINFEATURESIZE -1
>> COLOR 0 0 89
>> PARTIALS TRUE
>> FORCE FALSE
>> END
>> END
>> # Start of scalebar object
>> SCALEBAR
>> STATUS ON
>> COLOR 255 255 255
>> OUTLINECOLOR 0 0 0
>> BACKGROUNDCOLOR 0 0 0
>> UNITS KILOMETERS
>> INTERVALS 5
>> SIZE 150 5
>> STYLE 0
>> POSITION LL
>> LABEL
>> TYPE BITMAP
>> SIZE SMALL
>> OFFSET 0 0
>> BUFFER 0
>> MINDISTANCE -1
>> MINFEATURESIZE -1
>> COLOR 0 0 0
>> PARTIALS TRUE
>> FORCE TRUE
>> END
>> END
>> # Start of OutputFormat object
>> OUTPUTFORMAT
>> NAME "png"
>> MIMETYPE "image/png"
>> DRIVER "GD/PNG"
>> EXTENSION "png"
>> IMAGEMODE PC256
>> TRANSPARENT FALSE
>> END
>> LAYER
>> NAME "Contornos"
>> STATUS ON
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "user=postgres dbname=siguci host=localhost"
>> CLASSITEM "the_geom"
>> DATA "the_geom from contornos"
>> TYPE POLYGON
>> CLASS
>> NAME "contornos"
>> TEMPLATE ""
>> STYLE
>> SYMBOL 0
>> COLOR 0 128 0
>> OUTLINECOLOR 0 0 0
>> END
>> END
>> END
>> LAYER
>> NAME "Viales"
>> STATUS ON
>> DATA "the_geom from viales"
>> TYPE LINE
>> CLASS
>> NAME "viales"
>> TEMPLATE ""
>> STYLE
>> SYMBOL 0
>> COLOR 255 0 0
>> OUTLINECOLOR 0 0 0
>> END
>> END
>> END
>> LAYER
>> NAME "Areas deportivas"
>> STATUS ON
>> DATA "the_geom from areasdeportivas"
>> TYPE POLYGON
>> CLASS
>> NAME "areasdeportivas"
>> TEMPLATE "deportivas.html"
>> STYLE
>> SYMBOL 0
>> COLOR 255 255 0
>> OUTLINECOLOR 0 0 0
>> END
>> END
>> #HEADER "deportivas_header.html"
>> END
>> LAYER
>> NAME "Separadores"
>> STATUS ON
>> DATA "the_geom from separadores"
>> TYPE POLYGON
>> CLASS
>> NAME "separadores"
>> TEMPLATE ""
>> STYLE
>> SYMBOL 0
>> COLOR 0 128 0
>> OUTLINECOLOR 0 0 0
>> END
>> END
>> END
>> LAYER
>> NAME "Manzanas"
>> STATUS ON
>> DATA "the_geom from manzanas"
>> TYPE POLYGON
>> CLASS
>> NAME "manzanas"
>> TEMPLATE "manzanas.html"
>> STYLE
>> SYMBOL 0
>> COLOR 255 232 208
>> OUTLINECOLOR 0 0 0
>> END
>> END
>> #HEADER "manzanas_header.html"
>> # FOOTER "manzanas_footer.html"
>> END
>> LAYER
>> NAME "Edificios"
>> STATUS ON
>> DATA "the_geom from edificios"
>> TYPE POLYGON
>> CLASS
>> NAME "edificios"
>> TEMPLATE "edificios.html"
>> STYLE
>> SYMBOL 0
>> COLOR 192 192 192
>> OUTLINECOLOR 0 0 0
>> END
>> END
>> #HEADER "edificios_header.html"
>> #FOOTER "edificios_footer.html"
>> END
>> END
>> Ing. Alexander Rodriguez Torres.
>> Universidad de las Ciencias Informaticas.
>> E-Mail:atorres at estudiantes.uci.cu
OSGIS, Open Source GIS
http://www.osgis.nl
