Class expression and PostGIS
Paul Ramsey
pramsey at REFRACTIONS.NET
Sat Jun 24 14:22:52 EDT 2006
Try
EXPRESSION ('[object_type]' eq 'agents')
"=" is a numeric comparison, and you want a string comparison. The
extra '' around the attribute name also seem to help clarify things
for the expression parser.
On 23-Jun-06, at 4:10 PM, Nigel Gilbert wrote:
> [Many thanks to those who helped me yesterday overcome a problem with
> creating an oid index, now solved as a result of their advice]
> I have a PostGIS database including a table, world, with columns,
> object_type (containing either one of the strings, 'plants' or
> 'agents') and
> 'geom', containing points. In my map file I have:
> LAYER
> NAME World
> CONNECTIONTYPE postgis
> CONNECTION "user=..... dbname=...."
> DATA "geom from world"
> STATUS ON
> TYPE POINT
> CLASS
> NAME Agents
> EXPRESSION ([object_type] = 'agents')
> STYLE
> COLOR 255 111 207 # pink
> END
> END
> CLASS
> NAME Plants
> EXPRESSION ([object_type] = 'plants')
> STYLE
> COLOR 0 128 64 # green
> END
> END
> END
> This gives a map displaying nothing, although if I comment out the
> expressions, I get the points I would then expect. In other words,
> the
> expressions are always returning false. But getting the data
> directly:
> select object_type, AsText(geom) from world limit 3;
> object_type
> | astext
> plants
> | POINT(13 19)
> plants
> | POINT(228 840)
> plants
> | POINT(694 674)
> (3 rows)
> is fine. What's wrong??
> Thanks again!
> Nigel
