Thread-safety in mapscript_csharp.dll?
Fawcett, David
David.Fawcett at STATE.MN.US
Mon Jun 26 09:16:09 EDT 2006
That's the cool thing about opensource. If your paying customers are
demanding new features, you can improve the code base yourself, or fund
someone to add the functionality for you.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jeff Dege
Sent: Friday, June 23, 2006 4:06 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Thread-safety in
> From: Tamas Szekeres [mailto:szekerest at gmail.com]
> Sent: Friday, June 23, 2006 3:32 PM
> To: Jeff Dege
> Cc: MAPSERVER-USERS at lists.umn.edu
> Hi,
> MapServer was originally created to use in a single threaded
> application model, mapserv.exe is a single threaded CGI application.
> Using mapserver in a multithreaded environment should be handled with
> care.
I understand that. It's just what care I'm unsure of.
> One should take into account the following issues:
> 1. Since these unmanaged dll-s are using shared (global) variables and
> resources, multiple requests will use the same variables from
> different threads, and should be protected by locks.
Are you suggesting that we should protect access to the mapserver
objects within the C# code, using the C# lock statement? Or are the
locks within the mapscript_csharp.dll sufficient?
> 2. Mapscript objects members are not syncronized by locks so passing
> these objects between threads is to be avoided. 3. Mapscript objects
> should be properly disposed if not needed any more.
> Considering the previously mentioned facts we should draw at least the
> following conclusions:
> 1. Thread support should be enabled when compiling mapserver and
> mapscript C#. It will enable the locks on the shared variables for the
> most important components. Some of the components are not protected
> this way so those items should be avoided. See
> http://mapserver.gis.umn.edu/docs/faq/thread_safety for more details.
> 2. One should compile with only the features really needed by
> the application.
> 3. Should not retain mapscript objects between requests (eg. using in
> session variables).
> 4. Should use IDisposable.Dispose or the using{} clause to properly
> deallocate the unmanaged memory.
> Some of these conclusions may also apply to other languages using
> multithreaded application models.
> We are making some effort to eliminate the need of those variables and
> using "big locks" to increase the performance of the applications in
> multithreaded environments. To achieve this level most of the existing
> code should be reviewed. The first step for this activity was recorded
> at http://mapserver.gis.umn.edu/development/rfc/ms-rfc-15/ and will be
> enhanced upon the user's and developer's affinity for this issue. I'm
> considering few of the folks using mapserver and mapscript this way or
> they aren't complaining about much of these problems so far.
Google has changed things. Our customers are demanding mapping, and
demanding a more interactive mapping capability than they'd previously
been satisfied with. I think you'll see a growing interest in running
mapscript with ASP.NET and ATLAS.
