Raster image issue
Hooi
wchoonhooi at GMAIL.COM
Tue Jun 27 21:17:44 EDT 2006
Hi, all. I am new here.
I access to
http://localhost/cgi-bin/mapserv?map=test.map&layer=lakespy2&mode=map
but JPEG was displayed. FYI, I able to see vector image. Need help on this,
thanks.
Below is my mapserver version output:-
MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
I'm using GDAL 1.3.0
Below is output of #gdalinfo /var/www/cgi-bin/data/map.jpg
Driver: JPEG/JPEG JFIF
Size is 2524, 1738
Coordinate System is `'
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 1738.0)
Upper Right ( 2524.0, 0.0)
Lower Right ( 2524.0, 1738.0)
Center ( 1262.0, 869.0)
Band 1 Block=2524x1 Type=Byte, ColorInterp=Red
Band 2 Block=2524x1 Type=Byte, ColorInterp=Green
Band 3 Block=2524x1 Type=Byte, ColorInterp=Blue
Below is my mapfile :-
MAP
NAME ITASCA
STATUS ON
SIZE 600 600
EXTENT 388107.634400379 5203120.88405952 500896.339019834 5310243.30613897
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
TEMPLATEPATTERN "itasca"
IMAGETYPE JPEG
# Layer objects are defined beneath the map object. You need at least one
# layer defined in your map file before you can display a map... You can
# define as many layers as you'd like although a limit is typically
hard-coded
# in map.h in the MapServer source. The default limit is set at 100.
You'd
# have to have a very specialized application to need more than 100 layers
in
# your application.
# Start of LAYER DEFINITIONS ---------------------------------------------
WEB
HEADER templates/header.html
TEMPLATE "set in index.html"
FOOTER templates/footer.html
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "set in index.html"
IMAGEURL "set in index.html"
METADATA
WMS_TITLE "UMN MapServer Itasca Demo"
WMS_ABSTRACT "This is a UMN MapServer application for Itasca County
located in north central Minnesota."
WMS_ACCESSCONSTRAINTS "none"
# change this value to match your setup
WMS_ONLINERESOURCE "http://localhost/index.html"
WMS_SRS "EPSG:26915"
END
END
LAYER
NAME lakespy2
TYPE RASTER
STATUS ON
DATA map.tif
CLASS
NAME 'Lakes & Rivers'
TEMPLATE "templates/lakespy2.html"
STYLE
COLOR 49 117 185
END
END
HEADER "templates/lakespy2_header.html"
FOOTER "templates/lakespy2_footer.html"
TOLERANCE 3
DUMP TRUE # allow GML export
METADATA
WMS_TITLE "Lakes and Rivers"
WMS_ABSTRACT "DLG lake and river polygons for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlglkpy2.html for more
information."
END
END # lakes
LAYER
NAME dlgstln2
TYPE LINE
STATUS OFF
DATA dlgstln2
CLASS
NAME "Streams"
TEMPLATE "templates/dlgstln2.html"
STYLE
COLOR 49 117 185
END
END
HEADER "templates/dlgstln2_header.html"
FOOTER "templates/dlgstln2_footer.html"
TOLERANCE 5
METADATA
WMS_TITLE "Streams"
WMS_ABSTRACT "DLG streams for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlgstln2.html for more
information."
END
END # streams
END # All map files must come to an end just as all other things must come
to...
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060628/6e5c1fc3/attachment.html
