WMS and SRS issue
Ryan Ollerenshaw
ollerery at ENGR.ORST.EDU
Wed Jun 28 12:12:33 EDT 2006
Question 1:
I am using the SRS 4326 when trying to display a .tif image of canada. When i
set the extent on the top of the map file to: EXTENT -180 -90 180 90 i am only
getting a very small portion of the map, so i assume that the units begin used
by the extend are meters. I want to be able to specify the extent by lat/long.
How can i do this?
Question 2:
When using the web browser as a client my image displays just fine, but when i
try to connect to the same URL in ArcMap or uDig I can see the layers info but
no image gets displayed. uDig reports an error (Unable to decode image
returned from the server)
Thank you for any help that you can provide.
WMS URL:
http://neuron/cgi-bin/mapserv?map=../html/mapserver/htdocs/mywms.map&
SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=test_layer
Map FILE:
NAME WMSDEMO
STATUS ON
SIZE 500 400
EXTENT 0 0 2800 2800
#EXTENT -180 -90 180 90
#EXTENT -2200000 -712631 3072800 3840000
#UNITS METERS
SHAPEPATH "../data"
IMAGECOLOR 255 255 255
WEB
TEMPLATE test_template.html
IMAGEPATH "/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
WMS_TITLE "WMS test mapserver"
WMS_ACCESSCONSTRAINTS "none"
WMS_ONLINERESOURCE "http://neuron/cgi-bin/mapserv?map=mywms.map&"
WMS_SRS "EPSG:4326" #"AUTO:42003"
END
END
PROJECTION
"init=epsg:4326"
END
LAYER # Shaded Relief Raster
NAME test_layer
DATA bath_mapserver.tif
STATUS ON
TYPE RASTER
METADATA
WMS_TITLE "Shaded Relief Map of the Upper Great Lakes Region"
WMS_ABSTRACT "Shaded Relief Map, clipped from National Atlas dataset"
WMS_SRS "EPSG:4326"
WMS_FORMAT "image/png"
END
END
END # of map file
