Mapserver binaries for Oracle10g
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Jun 30 04:14:01 EDT 2006
Mapserv.exe is small since it depends on libmap.dll now. I.e. most of
the application code is now in a dll and not in the executable itself.
How to enable Oracle is explained in the MS4W readme file, excerpt
pasted here:
Steps to Enable Oracle 10g Support in MS4W
1. Make sure you have Oracle 10g client software installed on your
machine (the
same machine that you are running MS4W on).
2. Download libmap.dll for Oracle 10g from
http://hobu.stat.iastate.edu/mapserver/build_output/4_8_3
3. Replace the existing libmap.dll in /ms4w/Apache/cgi-bin/ with the
downloaded one.
4. Move the ogr_OCI.dll plugin file up one level from
/ms4w/gdalplugins/ignored/ into
/ms4w/gdalplugins/
5. Restart Apache to be safe.
6. For mapfile configuration see
http://mapserver.gis.umn.edu/docs/howto/oracle_spatial_howto
Best regards,
Bart
Antonio Iandolo wrote:
>Hi all,
>I'd like to set up an environment to use the native support for
>Oracle10g (not OGR) with MapServer
>I've downloaded MS4W 1.5.3, as stated on
>http://maptools.org/ms4w/index.phtml?page=downloads.html ("Note for
>Oracle users: Until bug#1499 is fixed, for Oracle connections you must
>use MS4W 1.5.3"), and so I have:
>MapServer version 4.8.3 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>OUTPUT=PDF
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
>SUPPORTS=WMS_SERVER SUPPO
>RTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
>SUPPORTS=WCS_SERVER SUPPO
>RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>INPUT=SH
>APEFILE DEBUG=MSDEBUG
>1) What am I missing to get the INPUT=ORACLESPATIAL with Mapserver?
>2) How come mapserv.exe is 32Kb, while it was about 3.120Kb before???
>3) Does anybody have a link to get windows binaries for MapServer 4.8.3
>built with Oracle support?
>Thanks in advance,
>Antonio
OSGIS, Open Source GIS
http://www.osgis.nl
