ka-map query
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Wed Mar 1 09:17:02 EST 2006
Hi Ben,
Use the ka-map package for ms4w
(http://www.maptools.org/ms4w/index.phtml?page=downloads.html) and
extract it to the same drive root as your ms4w install - it will extract
the ka-map files into ms4w properly.
Note that you may want to use the ka-map mailing list
(http://lists.maptools.org/mailman/listinfo/ka-map-users), or the IRC
online chat room for ka-map at:
Server: irc.freenode.net
Channel: #kamap
jeff
Ben Crane wrote:
> 1. I can get mapserver.exe to run without a problem,
> but kamap doesn't unpack into the htdocs folder under
> msmw. Where do I need to put the kamap htdocs folder
> for it to be accessed? The tutorial doesn't
> specifically tell you. I'm presuming ALL the
> data/html, etc it will need to be under the msmw
> htdocs folder?
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
