Shape layer is not shown. Please help
Baris YILMAZ
baris_999 at YAHOO.COM
Thu Mar 2 10:21:48 EST 2006
I did the changes you told me and now it works. Thank you all who helped on the matter. Best regards
Baris
Travis Kirstine GIS Tech <tkirstine at jdbarnes.com> wrote: Firstly, you should define a symbols.sym file that will be used to draw your map symbols (points, lines, polygons)
It is declared in the map object just liike SHAPEPATH. By default mapserver will only draw points as one pixel if there is no
symbol defined
SYMBOLSET your path to the symbol.sym file e.g. /var/www/html/map_symbols/symbols.sym
open the symbol.sym file with a text editor and add the following
SYMBOL
NAME 'circle'
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
Save the file and close, Add the following to your Brunnen CLASS in the mapfile
CLASS
NAME "Brunnen"
COLOR 255 0 0
OUTLINECOLOR 0 255 0
SYMBOL 'circle'
SIZE 12
END
Travis
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Baris YILMAZ
Sent: Wednesday, March 01, 2006 9:46 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Shape layer is not shown. Please help
I have a map file, which has two layers, one a raster layer, and the other a shapefile. But the raster layer is shown whereas the layer Brunnen (shapefile) is not shown. Can anyone help? I checked the path of the shape file and it is ok.. Can anyone help me please? Is there anything missing in the layer definitions of the layer "Brunnen"? My shapefile contains just cross symbols.
Thank you.
Baris
Below my mapfile;
MAP
EXTENT 3439438.15784499212000 5501464.74457754190000 3440160.4830 5511464.6416
IMAGECOLOR 240 240 240
IMAGETYPE png
SHAPEPATH "C:/ms4w/apps/Data/KartenSHP/GWMshp/"
SIZE 500 400
STATUS ON
UNITS METERS
NAME "Hessischer Ried"
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE "PC256"
TRANSPARENT FALSE
END
PROJECTION
"proj=lcc"
"lat_1=32"
"lat_2=44"
"lat_0=38"
"lon_0=-100"
"x_0=0"
"y_0=0"
"ellps=GRS80"
"datum=NAD83"
END
LEGEND
IMAGECOLOR 255 255 255
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
STATUS EMBED
TEMPLATE "C:/ms4w/apps/maplab-2.2.1/htdocs/mapbrowser/legend_template.html"
END
QUERYMAP
COLOR 255 255 0
SIZE -1 -1
STATUS OFF
STYLE HILITE
END
SCALEBAR
COLOR 0 0 0
INTERVALS 4
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
END
POSITION LL
SIZE 200 3
STATUS OFF
STYLE 0
UNITS MILES
END
WEB
IMAGEPATH "C:/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
METADATA
END
QUERYFORMAT text/html
END
LAYER
DATA "C:\ms4w\apps\Data\KartenSHP\Karten\TK25\60xx\6015SI_96.tif"
METADATA
END
NAME "Ried"
SIZEUNITS METERS
STATUS ON
TOLERANCEUNITS PIXELS
TYPE RASTER
UNITS METERS
END
LAYER
NAME "Brunnen"
STATUS DEFAULT
DATA "Brunnen"
TYPE POINT
UNITS METERS
SIZEUNITS PIXELS
METADATA
END
PROJECTION
"proj=lcc"
"lat_1=32"
"lat_2=44"
"lat_0=38"
"lon_0=-100"
"x_0=0"
"y_0=0"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "Brunnen"
END
END
END
Yahoo! Mail
Bring photos to life! New PhotoMail makes sharing a breeze.
Yahoo! Mail
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060302/8abd3768/attachment.html
