Tileindex of DGN's being opened as shapefile layer
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Fri Mar 3 02:57:29 EST 2006
Hi Jacob,
I can only state that I have seen this problem as well myself with
Mapinfo TAB files in a tileindex, I was also using them through
PHP/Mapscript. In the end I used Mapinfo seamless layers to get around
that, but that won't be an option for your DGN's.
Best regards,
Bart
Delfos, Jacob wrote:
> Hi,
> Just to provide some additional information: the map displays fine in
> mapserver, but not in php_mapscript. It appears that php_mapscript
> assigns a shapefile connectiontype to this layer, causing it to try to
> open the DGN's as shapefile. In the mapserver CGI, this doesn't
> happen. Can anyone with a better understanding of the difference
> between the two tell me what I can do to get around it?
> regards,
> Jacob
> *From:* UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] *On Behalf Of *Delfos, Jacob
> *Sent:* 20 February 2006 15:00
> *To:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Subject:* [UMN_MAPSERVER-USERS] Tileindex of DGN's being opened
> as shapefile layer
> Hi All,
> I'm having some trouble creating a tile-index of DGN's, using
> php_mapscript (Chameleon). My tileindex is a shapefile. But I
> think the layer should be treated as OGR, yet the connectiontype
> seems to indicate it thinks it is a shapefile layer. According to
> my PHP log, it tries to open it as a shapefile, which obviously fails:
> [20-Feb-2006 14:45:49] PHP Warning: [MapServer Error]:
> msDrawMap(): Failed to draw layer named 'DGNs'.
> in C:\chameleon\htdocs\common\wrapper\drawmap.php on line 560
> msTiledSHPOpenFile(): Unable to open a single tile to use as a
> template in layer DGNs.
> msSHPOpenFile(): (c:/data/hongkong/10nwb.dgn)
> msSHPOpenFile(): (c:/data/hongkong/10nwa.dgn)
> I based my layer definition on
> _http://mapserver.gis.umn.edu/docs/howto/ogr_howto/#tileindex-with-ogr_
> LAYER
> NAME "DGNs"
> TYPE LINE
> STYLEITEM "AUTO"
> CONNECTIONTYPE OGR
> TILEINDEX "dindex.shp,0"
> STATUS ON
> CLASS
> COLOR 150 150 150
> END
> END
> The DBF of the shapefile has 1 column, with these values:
> location
> C:\data\10nwa.dgn,0
> C:\data\10nwb.dgn,0
> I am using php_mapscript 4.6.1, with php 5.05. Can someone tell me
> what I'm doing wrong?
> Regards,
> Jacob
> *JACOB DELFOS
> GIS ANALYST
> *Maunsell Australia Pty Ltd
> 629 Newcastle Street, Leederville, WA 6007
> PO Box 81, Leederville, WA 6902
> Western Australia
> ABN 20 093 846 925
> Tel + 61 8 9281 6185
> Fax + 61 8 9281 6297
> _jacob.delfos at maunsell.com_
OSGIS, Open Source GIS
http://www.osgis.nl
