threads in mapserv
    Chris Tweedie
    chris at NARX.NET
    Fri Mar  3 03:20:21 PST 2006
Hi Frank/Paul
Tim and myself have been trying to get fcgi support running with no success.
Briefly, we cannot get past the following exception when submitting a
standard getcapabilities call ...
[Fri Mar  3 12:04:44 2006] [warn] FastCGI: (dynamic) server
"/MapServer/www/cgi-bin/mapserv.fcgi" started (pid 32471)
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
"/MapServer/www/cgi-bin/mapserv.fcgi" (pid 32471) terminated by calling
exit with status '0'
Does this ring any bells with you in your implementations? It seems as
though the fcgi handler is not passing on the query string, which is
causing mapserv to throw the usual "Should be initiated as a cgi
process". The reason though, i have no idea. The same executable, when
fcgi is disabled works as expected ... all the SDE connections have the
defer parameter defined in the map file.
Our complete configuration is as follows .. any thoughts/ideas would be
muchly appreciated.
1. Unpacked fcgi-2.4.0 to /WSPACE5/fcgi-2.4.0
2. Built and installed library to /WSPACE5/fcgi_bin
3. Unpacked mod_fastcgi.so
4. Modified httpd.conf
Options Indexes FollowSymLinks MultiViews ExecCGI
AddHandler fastcgi-script fcgi
FastCgiConfig -initial-env PROJ_LIB=/MapServer/lib -initial-env
LD_LIBRARY_PATH=/MapServer/lib -appConnTimeout 60 -idle-timeout 60
-init-start-delay 1 -minProcesses 2 -maxClassProcesses 20 -startDelay 5
LoadModule fastcgi_module /MapServer/mod_fastcgi.so
5. Built mapserv.fcgi with the following configuration
./configure --with-proj --with-ogr --with-gdal --with-wfs --with-wcs
--with-wmsclient --with-wfsclient --with-sde-version=91
--with-sde=/arcsdesdk/sdeexe91/lib/  --with-fastcgi=/WSPACE5/fcgi_bin
[root at t2lin cgi-bin]# ./mapserv.fcgi -v
MapServer version 4.6.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
SUPPORTS=WCS_SERVER INPUT=EPPL7 INPUT=SDE INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
[root at t2lin cgi-bin]# ldd ./mapserv.fcgi
        libgd.so.2 => /MapServer/lib/libgd.so.2 (0x00fa9000)
        libjpeg.so.62 => /MapServer/lib/libjpeg.so.62 (0x00789000)
        libfreetype.so.6 => /MapServer/lib/libfreetype.so.6 (0x00ed9000)
        libpng.so.3 => /MapServer/lib/libpng.so.3 (0x006d8000)
        libz.so.1 => /usr/lib/libz.so.1 (0x00b2f000)
        libproj.so.0 => /MapServer/lib/libproj.so.0 (0x008dd000)
        libsde91.so => /arcsdesdk/sdeexe91/lib/libsde91.so (0x00cae000)
        libpe91.so => /arcsdesdk/sdeexe91/lib/libpe91.so (0x00246000)
        libsg91.so => /arcsdesdk/sdeexe91/lib/libsg91.so (0x00b58000)
        libpthread.so.0 => /lib/tls/libpthread.so.0 (0x00111000)
        libdl.so.2 => /lib/libdl.so.2 (0x00f92000)
        libgdal.so.1 => /MapServer/lib/libgdal.so.1 (0x00ff8000)
        libcurl.so.3 => /MapServer/lib/libcurl.so.3 (0x00377000)
        libssl.so.4 => /lib/libssl.so.4 (0x00af1000)
        libcrypto.so.4 => /lib/libcrypto.so.4 (0x00121000)
        libgssapi_krb5.so.2 => /usr/kerberos/lib/libgssapi_krb5.so.2
(0x00213000)
        libkrb5.so.3 => /usr/kerberos/lib/libkrb5.so.3 (0x004db000)
        libcom_err.so.3 => /usr/kerberos/lib/libcom_err.so.3 (0x00226000)
        libk5crypto.so.3 => /usr/kerberos/lib/libk5crypto.so.3 (0x005a7000)
        libresolv.so.2 => /lib/libresolv.so.2 (0x00539000)
        libc.so.6 => /lib/tls/libc.so.6 (0x00911000)
        libfcgi.so.0 => /fcgi_lib/lib/libfcgi.so.0 (0x0054b000)
        libm.so.6 => /lib/tls/libm.so.6 (0x00c69000)
        libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x007f3000)
        libpng12.so.0 => /MapServer/lib/libpng12.so.0 (0x00554000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x00585000)
        /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x00230000)
        libodbc.so.1 => /MapServer/lib/libodbc.so.1 (0x005b9000)
        libxerces-c.so.26 => /MapServer/lib/libxerces-c.so.26 (0x060ee000)
        libNCSEcw.so => /ecwsdk/lib/libNCSEcw.so (0x05ecb000)
        libNCSCNet.so => /ecwsdk/lib/libNCSCNet.so (0x0058e000)
        libNCSUtil.so => /ecwsdk/lib/libNCSUtil.so (0x0061d000)
        libgeotiff.so => /MapServer/lib/libgeotiff.so (0x0062e000)
        libtiff.so.3 => /MapServer/lib/libtiff.so.3 (0x00650000)
        libnetcdf.so => /MapServer/lib/libnetcdf.so (0x0069c000)
        libpq.so.4 => /MapServer/lib/libpq.so.4 (0x00c15000)
        librt.so.1 => /lib/tls/librt.so.1 (0x006c1000)
        libnsl.so.1 => /lib/libnsl.so.1 (0x00709000)
        libcrypt.so.1 => /lib/libcrypt.so.1 (0x0071e000)
*** Although no SUPPORTS=FASTCGI displayed for mapserv.fcgi -v, the ldd
shows libfcgi.so.0 => /fcgi_lib/lib/libfcgi.so.0 (0x0054b000) indicating
it is using the library. Or is it?
6. Pressed on to see if we got lucky, so did a getcapabilities
[root at t2lin logs]# tail -f error_log
[Fri Mar  3 12:04:17 2006] [notice] caught SIGTERM, shutting down
Processing config directory: /MapServer/www/conf.d/*.conf
Processing config file: /MapServer/www/conf.d/gdal.conf
Processing config file: /MapServer/www/conf.d/mapserver.conf
Processing config file: /MapServer/www/conf.d/php.conf
Processing config file: /MapServer/www/conf.d/proj.conf
[Fri Mar  3 12:04:19 2006] [warn] NameVirtualHost *:80 has no VirtualHosts
[Fri Mar  3 12:04:19 2006] [notice] FastCGI: process manager
initialized (pid 32464)
[Fri Mar  3 12:04:19 2006] [notice] Apache/1.3.34 (Unix)
mod_fastcgi/2.4.2 configured -- resuming normal operations
[Fri Mar  3 12:04:19 2006] [notice] Accept mutex: sysvsem (Default: sysvsem)
***** SUBMITTED GETCAPABILITIES START HERE *********
[Fri Mar  3 12:04:49 2006] [warn] FastCGI: (dynamic) server
"/MapServer/www/cgi-bin/mapserv.fcgi" restarted (pid 32473)
"/MapServer/www/cgi-bin/mapserv.fcgi" (pid 32473) terminated by calling
[Fri Mar  3 12:04:54 2006] [warn] FastCGI: (dynamic) server
"/MapServer/www/cgi-bin/mapserv.fcgi" restarted (pid 32476)
"/MapServer/www/cgi-bin/mapserv.fcgi" (pid 32476) terminated by calling
[Fri Mar  3 12:04:59 2006] [warn] FastCGI: (dynamic) server
"/MapServer/www/cgi-bin/mapserv.fcgi" restarted (pid 32477)
"/MapServer/www/cgi-bin/mapserv.fcgi" (pid 32477) terminated by calling
"/MapServer/www/cgi-bin/mapserv.fcgi" has failed to remain running for
30 seconds given 3 attempts, its restart interval has been backed off
to 600 seconds
7. FastCGI continues to output Error 500 while looping thru the above
continuously.
*pulls hair out*
More information about the MapServer-users
