MapServer incompatibility with RHEL4/CE NTOS4.2
Lowell.Filak
lfilak at MEDINACO.ORG
Fri Mar 3 13:05:38 EST 2006
Doyon, Jean-Francois writes:
> I tried moving the RedHat 7.3 binary that I know works fine to a CentOS 4.2
> system, and wham, the problem appeared!
> I also investigated trying to run multiple glibc's to see if that might be
> the problem (i.e. install the RedHat 7.3 glibc on CentOS for the use of
> MapServer), but that looks like quite the nightmare to try out ...
J.F.,
Wouldn't the binary from the 7.3 box still be using the gd libs on the RHEL
box though, or did you statically links things.?
Lowell
