MapServer incompatibility with RHEL4/CE NTOS4.2
Lowell.Filak
lfilak at MEDINACO.ORG
Fri Mar 3 13:20:03 EST 2006
Doyon, Jean-Francois writes:
> No, the linking is dynamic so you just move the executable, and it starts
> using the libs on the current box. There was some incompatibility between
> libraries, so I had to remove PNG and SSL/Crypto support from the excutable
> I was compiling on 7.3 before moving it over. Like I said, it ran fine on
> CentOS, using CentOS' libs, but the "bug" was still there ...
Then if the libs aren't the same the bug is in the libs, no?
This doesn't point to gcc being the problem.
Lowell
