GetLegendGraphic and sld
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Mon Mar 6 08:44:34 EST 2006
Tom,
If you set the name parameter inside the rule, It will be used to set
the class name on the layer. The class name is the one that is used as
text in the legend. (Bug 1451 is realted to this).
Later,
Kralidis,Tom [Burlington] wrote:
> Hi,
> Does MapServer's OGC:WMS GetLegendGraphic support changing of legend text in addition to the actual graphic mark? We're able to do the latter via SLD, but we can't seem to change the legend text.
> We're using latest CVS.
> Test URL:
> http://devgeo.cciw.ca/cgi-bin/mapserv/hydromet?version=1.1.1&service=WMS&request=GetLegendGraphic&layer=hydromet_latest_water_levels&format=image/jpeg&sld=http://devgeo.cciw.ca/ms_tmp/kyw_sld.xml
> Under the hood, the data from the OGC:WMS is a point layer, with the following CLASS block:
> CLASS
> NAME "Water Levels"
> SYMBOL 'circle'
> SIZE 3
> COLOR 0 0 255
> END
> ...so I'm not sure whether something has to be enabled from the server end to enable the SLD to specify titles, or if the SLD is off.
> Please advise.
> Thanks
> ..Tom
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
