Quest for knowledge
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Mar 6 09:55:57 EST 2006
Gary Watry wrote:
> Good Morning
> Is there a way using html or javascript that the end user can plot subset of
> data based on a column short of building a layer for each choice.
> column is years, i.e 1992, 1992, 1994
> they could [pick year]
> thanks
> p.s. I am learning PHP but can not use it yet
If you are using mapserver CGI, you could create a form to select the
year and return it in say YEAR variable, then in the layer you can set
up a filter and reference %YEAR% in the mapfile and mapserver should do
the substitution for you.
-Steve W.
