map file in tmp directory
Puneet Kishor
punkish at EIDESIS.ORG
Mon Mar 6 10:19:42 EST 2006
On Mar 6, 2006, at 9:17 AM, Chip Taylor wrote:
> As opposed to map mode. Map mode streams the image directly to the
> browser
> and does not create the image in the ImagePath
ahhh! There you go. You solved your problem. ;-)
Wrt, the "browse" mode, yes, you will have to remove the temp files
yourself, but it is a trivial task happily tackled by your operating
system. Why bother MapServer with housekeeping... it has bigger things
to accomplish.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> On
> Behalf Of Puneet Kishor
> Sent: Monday, March 06, 2006 7:10 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] map file in tmp directory
> On Mar 6, 2006, at 9:01 AM, Chip Taylor wrote:
>> I was aghast to find over 4,000 files in my /tmp directory. That is
>> the
>> directory I have designated as the IMAGEPATH and IMAGEURL for
>> MapServer. I
>> know that these files are only created if MapServer is run in Browse
>> mode.
> as opposed to what other mode?
Puneet Kishor
