C# mapscript...
Abe Gillespie
abe.gillespie at GMAIL.COM
Tue Mar 7 11:21:19 EST 2006
Here we go again ... :)
I was afraid this thread would eventually devolve to trying to get C#
MapScript working for the web. Unfortunately IIS / ASP.NET (I'm
assuming you're using ASP.NET) threading model renders the C#
MapScript Assembly virtually useless when used in this context.
Here's slightly more info:
http://mapserver.gis.umn.edu/docs/faq/thread_safety/?searchterm=thread
Good luck!
-Abe
On 3/7/06, John Cole <john.cole at uai.com> wrote:
> Howard,
> I'm trying to get your 4.8.1 build (thank you for making that) to work
> with IIS. Searching the website, there isn't a guide on setting this up.
> I've gotten IIS to work with MS4W before, but I'm getting a 502 when I try
> to hit this version.
> Mapserv -v returns the following:
> C:\Inetpub\cgi-bin>mapserv -v
> MapServer version 4.8.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPO
> RTS=THREADS SUPPORTS=GEOS INPUT=JPEG INPUT=SDE INPUT=POSTGIS INPUT=OGR
> INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
> So I'm pretty sure it's ready to go, and I've also made a decent stab at
> getting the permissions correct. Is there something that I've missed?
> I'm on XP SP2 IIS 5
> Thanks,
> John Cole
> -----Original Message-----
> From: Howard Butler [mailto:hobu at iastate.edu]
> Sent: Monday, March 06, 2006 9:53 AM
> To: John Cole; MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: C# mapscript...
> John,
> Grab the build kit. All of the dependencies have been built
> already. All you have to worry about are gdal and mapserver.
> <http://hobu.stat.iastate.edu/mapserver/build_output/mapserver-4.8-msvc71-bu
> ild-kit.zip>
> Make sure to edit nmake.opt for GDAL and make a clean GDAL (and then
> do nmake /f makefile.vc install). Edit nmake.opt for MapServer, make
> clean, and make install for MapServer and you should end up with a
> csharp directory in ..\bin with the C# mapscript binaries.
> Catch me on IRC if you have questions. Then we can write a doc ;)
> Howard
> At 09:42 AM 3/6/2006, John Cole wrote:
> >Tamas,
> > Thanks for your help, some more questions now :-)
> > I've switched to the nightly.tar.gz (because I couldn't figure out flex
> >and bison) but I'm having trouble with libpng. I've checked their site and
> >there isn't a lot of info on building with windows, much less building in
> >VC8, how did you do it? I'm getting the following error trying to build
> the
> >libpng solution
> >Error 1 fatal error A1000: cannot open file :
> >c:\projects\zlib\contrib\masmx86\inffas32.asm MASM
> >I have the zlib library but that file doesn't exist in it (nor does the
> >masmx86 directory).
> > Also, I was the nmake /F Makefile.vc was getting errors on not finding
> >bgd_i.lib, so I changed those references to bgd.lib, is that OK? (it got
> >past that).
> >Thanks,
> >John Cole
> >From: Tamas Szekeres [mailto:szekeres.tamas at FREEMAIL.HU]
> >Sent: Friday, March 03, 2006 3:58 PM
> >To: MAPSERVER-USERS at LISTS.UMN.EDU; John Cole
> >John,
> >The parser and lexer files are not precompiled with the CVS version. You
> >have at least 2 options to do:
> >1. Use the nightly build instead containing theese files precompiled
> >http://cvs.gis.umn.edu/dist/nightly.tar.gz
> >2. Download flex and bison
> >gnuwin32.sourceforge.net/packages/flex.htm
> >gnuwin32.sourceforge.net/packages/bison.htm
> >and generate theese files from mapparser.y and maplexer.l
> >Best Regards,
> >Tamas
