PHPMapscript
Doug Williams
williams at WEBSAWYER.COM
Tue Mar 7 12:15:29 EST 2006
VolComHG,
That is weird how you are building out a mapserver forum at Nabble through
UMN's Mapserver list. Not sure if that is cool. I would suggest you simply
make a page that points to the real Mapserver. Perhaps you will have better
luck with getting your mapserver running.
If you are getting two popups by adding the bit of code I sent you, then I
suggest you start by reinstalling your OS after reformatting your harddrive.
>VolCanHG "VolComHG (sent by Nabble.com)" <lists at NABBLE.COM> wrote:
>Hi Doug, tx for your code, the result is when i open my page 2 popup appear
>: 1- "Failure" 2-"Already loaded (i doubt it"), what i must do now ????
>here my code
><?php
>if (!extension_loaded("MapScript")){
> if (dl('php_mapscript_46.dll')) {
> echo "<script>window.alert('success');</script>";
> }else{
> echo "<script>window.alert('failure');</script>";
>}else{
> echo "<script>window.alert('already loaded (i doubt it)');</script>";
>$map_path="C:/ms4w/apps/kamap-0.1.1/htdocs/";
>$map = ms_newMapObj($map_path."global.map");
>$image=$map->draw();
>$image_url=$image->saveWebImage();
