Projection issues on WFS-Server
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Wed Mar 8 09:30:03 EST 2006
Stephan,
From what I have seen, this happens when the layer does not have a
projection object (with possibly an espg code) that reflects the
projection of your layer.
This can easily be reproduced if I set a projection object at the map
level (or metadata wfs_srs = "EPSG:4326") and I use a layer which is not
in lat/long and does not have a projection object.
In that case the default fallback is to assume that the layer is the
same projection as the map. If the layer has a valid projection, there
will be a reprojection of the extents.
Stephan, is this the case for you ?
Frank Warmerdam wrote:
> Stephan Holl wrote:
>> Hello Frank,
>> On Tue, 7 Mar 2006 15:12:20 -0500 Frank Warmerdam <warmerdam at POBOX.COM>
>> wrote:
>>> Stephan Holl wrote:
>>>> GetCapabilities
>>>> <SRS>EPSG:4326</SRS>
>>>> <LatLongBoundingBox minx="-2.5e+07" miny="-2.5e+07" maxx="2.5e+07"
>>>> maxy="2.5e+07"/>
>>>> This should be from my understanding
>>>> <LatLongBoundingBox minx="-180" miny="-90" maxx="180" maxy="90"/>
> Stephan,
> Looking more closely at your bounding box, it doesn't really look
> like it hasn't been reprojected. It looks more like it was unitialized
> or defaulted somehow since all the values are the same.
> I am also starting to wonder if this is an issue specific to PostGIS.
> I'm no WFS nor PostGIS-in-MapServer guru. My suggestion is you try
> and reproduce the problem from shapefiles. If you can reproduce it
> from shapefiles, then you should submit a bug report with a dataset,
> map and the exact WFS query to reproduce the problem. You should
> test the WFS query against mapserv at the commandline to maximally
> ensure it will be easy for the bug fixer to reproduce.
> If you can't reproduce the problem with a shapefile, then I suspect
> the issue is somehow related to WFS interacting with the PostGIS driver.
> You likely still ought to file a bug, but it will likely be hard to
> bundle things up to make it easy for a bug fixer to reproduce.
> Best regards,
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
