newbie question {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Sat Mar 11 08:52:03 EST 2006
Hi Etienne,
First you have to select your favorite language for mapscript, there are
several choices, php, pyton, perl, c#, ....
First check mapserver.gis.emn.edu/docs page, there are reference, howto
and faq topics.
I started with
http://mapserver.gis.umn.edu/docs/howto/phpmapscript-byexample
GMap is a sample application written in php. You cab customize it for your
aims.
http://www.maptools.org/dl/gmap-ms46.zip
Chameleon is high level approache, few programming neccessary
http://chameleon.maptools.org
I have used phpmapscript so far.
I hope this helps you
Zoltan
On Sat, 11 Mar 2006, Etienne Sévin wrote:
> That's it Zoltan, thanks for your answer
> I wanna be able to use the two ways, but the second one is really the
> way I wanna go first.
> So it will be MapScript.
> Is there any good document to start with ?
> Do I have to redefine boundaries for every map or is there already
> something existing ?
> best regards,
> Etienne
> Siki Zoltan a écrit :
> >Hi Etienne,
> >If you would like to display predefined thematic maps then mapserver CGI
> >is ready to do it. If you would like to define class boundaries and
> >style on the fly you can use mapscript, but you also have to create the
> >user interface to set up styles.
> >Zoltan
> >On Fri, 10 Mar 2006, [ISO-8859-1] Etienne Sévin wrote:
> >>Hi there,
> >>We are planning to add a MapServer plugin to our online survey
> >>application to allow user to build thematic analysis.
> >>I'm really new to GIS and most of the examples I saw about mapserver
> >>were issues about geographic localization.
> >>Where could I find examples about how to build thematic analysis like
> >>the one we can find in a mapinfo package for instance?
> >>I hope this question is not too dumb ...
> >>best regard,
> >>Etienne
