Problems Installing New MapServer Version 4.8.1 on Windows
Server 2003 IIS 6.0
Brent T. Dukes
bdukes at ARKIONSYSTEMS.COM
Tue Mar 14 08:39:21 EST 2006
Gail,
Please check your IIS Manager under "Web Service Extensions" Be sure "All
Unknown CGI Extensions" is set to "Allowed" (at least for testing). If this
makes it work, you can look up how to set Mapserver.exe to a 'known' CGI
extension. I don't have any details on this.
If this doesn't fix your problem I can relay you all my Web Site and
Application Pool settings. I can assure you I have the CGI version of
Mapserver running on IIS 6/Server 2003 with no problems. C# MapScript is
another story ;)
-Brent T. Dukes
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Gail Millin
Sent: Tuesday, March 14, 2006 7:43 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Problems Installing New MapServer Version
4.8.1 on Windows Server 2003 IIS 6.0
Dear MapServer Users,
I would like to install MapServer 4.8.1 on Windows Server 2003 and IIS 6.0.
However documentation on the MapServer website keeps taking me to the MS4W
Installer which is configured for an Apache server. I have consulted the
Win32 Compilation and Installation How To document however the link to the
MapServer source code that is suggested in this document is broken
(http://mapserver.gis.umn.edu/dload.html ). I have downloaded the files from
the MS4W installer and tried to adapt the configuration to IIS 6.0. I have
managed to install PHP and Mapscript and when I run the test.php script I
have
MapScript
MapServer Version
MapServer version 4.8.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=JPEG INPUT=POSTGIS INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
PHP MapScript Version
($Revision: 1.242.2.1 $ $Date: 2006/01/18 00:37:47 $)
However when I type http://localhost/cgi-bin/mapserv.exe I do not get the
message No query information to decode. Query_String is set, but empty.
Instead I get The Page Cannot be Found HTTP Error 404 - File or directory
not found.Internet Information Services (IIS).
I have checked my permissions on cgi-bin directory which has the executable
rights switched on, I really cannot think of what is causing this to occur?
Also is there no where that provides Mapserver 4.8.1 windows binaries
without having to install the ms4w package?
I would appreciate any help or suggestions from anyone that has successfully
installed Mapserver 4.8.1 on IIS 6 Windows 2003
Kind Regards
Gail
Gail Millin
E-mail: Gail.Millin at manchester.ac.uk
Website: http://www.landmap.ac.uk
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060314/0cb50417/attachment.html
