php error with ogr odbc
Mark Adams
markadams at CUESTASYS.COM
Tue Mar 14 09:36:58 EST 2006
I'm on Windows 2003 Server. The Mapserver version is 4.9, a custom build
from DM Solutions with ArcSDE support and the new contains query option.
GDAL is 1.3.1, this is the only version of the dll in the Windows System32
folder. I also installed fwtools so I could run ogrinfo, this is using its
own version of gdal in the fwtools bin folder, but I don't think this would
interfere with what mapserver/mapscript is using.
On Mon, 13 Mar 2006 22:00:03 -0800, Eijnden, B. van den (Bart)
<b.vdeijnden at AGI.RWS.MINVENW.NL> wrote:
>A few questions:
>a) on which platform are you?
>b) which Mapserver/Mapscript version?
>c) which GDAL version?
>Assuming you might be on Windows, you did not by any chance drop in another
>gdal dll in your Mapserver/Mapscript install?
>Bart
>-----Oorspronkelijk bericht-----
>Van: UMN MapServer Users List
>[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]Namens Mark Adams
>Verzonden: maandag 13 maart 2006 22:56
>Aan: MAPSERVER-USERS at LISTS.UMN.EDU
>Onderwerp: [UMN_MAPSERVER-USERS] php error with ogr odbc
>Hi all,
>I'm trying to connect to Oracle and display a set of points using the OGR
>virtual data driver. From ogrinfo I get a successful result (well, first
>and error 1 - setattributefilter() not supported on executesql() results -
>but then a successful listing of feature attributes). From my php mapscript
>application however I get a visual C++ runtime error from php: "This
>application has requested the Runtime to terminate it in an unusual way.
>Please contact the application's support team for more information."
>My OVF file looks like this:
><OGRVRTDataSource>
> <OGRVRTLayer name="showings">
><SrcDataSource>ODBC:minf_p1/minf_p1 at NORMINA,MINFT_SHOWN_SHOWING</SrcDataSou
r
>ce>
> <SrcSQL>select MINFT_SHOWN_SHOWING.* from
>MINFT_SHOWN_SHOWING</SrcSQL>
> <GeometryType>wkbPoint</GeometryType>
> <GeometryField encoding="PointFromColumns" x="C_SHOWN_LONGITUDE"
>y="C_SHOWN_LATITUDE"/>
> </OGRVRTLayer>
></OGRVRTDataSource>
>Has anyone encountered this error before, and is this a configuration
>problem, compilation problem, or something else?
>Thanks in advance,
>Mark Adams
>markadams at cuestasys.com
>Disclaimer
>Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
>hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
>informeren. Wij adviseren u om bij twijfel over de juistheid of de
>volledigheid van de mail contact met afzender op te nemen.
>This message shall not constitute any rights or obligations.
>This message is intended solely for the addressee.
>If you have received this message in error, please delete it and
>notify the sender immediately. When in doubt whether this message
>is correct or complete, please contact the sender.
