WMS projection error...
John Cole
john.cole at UAI.COM
Wed Mar 15 16:46:05 EST 2006
Frank,
I already had a line like:
CONFIG PROJ_LIB "/ms4w/proj/nad"
I changed it to
CONFIG PROJ_LIB "C:/ms4w/proj/nad"
And get the same results.
Is there another config? The mapserver web pages seem to be working
normally; otherwise.
Thanks,
John
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank
Warmerdam
Sent: Wednesday, March 15, 2006 3:37 PM
To: John Cole
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WMS projection error...
John Cole wrote:
> I'm trying to use Gaia 2.0.4 from www.thecarbonproject.com to view a map
map
> 4.8.1 mapserver from MS4W (using IIS and not Apache) and I'm getting the
> following error:
> msProcessProjection(): Projection library error. No such file or directory
> If I browse to the map using mode=browse it works fine (it did have a
> similar error through the browser, but a config fixed it and adding the
> PROJ_LIB path to my environment variables also fixed it).
> Hitting the same mapfile with mapserver 4.4 works fine.
> Is there another parameter to tell wms where the proj files are?
John,
One way of handling this is to have a CONFIG directive on your map object.
I think this would look something like:
MAP
CONFIG "PROJ_LIB" "C:/PROJ/NAD"
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGF, http://osgeo.org
