WMS projection error...
Nikos
nicolas at MAICH.GR
Thu Mar 16 02:42:41 EST 2006
Frank Warmerdam wrote:
> John Cole wrote:
>> I'm trying to use Gaia 2.0.4 from www.thecarbonproject.com to view a
>> map map
>> 4.8.1 mapserver from MS4W (using IIS and not Apache) and I'm getting the
>> following error:
>> msProcessProjection(): Projection library error. No such file or
>> directory
>> If I browse to the map using mode=browse it works fine (it did have a
>> similar error through the browser, but a config fixed it and adding the
>> PROJ_LIB path to my environment variables also fixed it).
>> Hitting the same mapfile with mapserver 4.4 works fine.
>> Is there another parameter to tell wms where the proj files are?
> John,
> One way of handling this is to have a CONFIG directive on your map
> object.
> I think this would look something like:
> MAP
> CONFIG "PROJ_LIB" "C:/PROJ/NAD"
> Best regards,
You can also set an environment variable PROJ_LIB, and ms seems to
figure it out..;-)
regards,
nikos
