VS: [UMN_MAPSERVER-USERS] Setup mapserver iis
Rahkonen Jukka
Jukka.Rahkonen at MMMTIKE.FI
Fri Mar 24 02:09:02 EST 2006
Nothing to say about IIS, but once you have it running I suppose you won't still get anything visible by using your request. All your layers seem to have "STATUS ON" and it means that they are NOT showed if you are not specifically requesting for it. Either add "&layers=" argument to your request, or change at least one layer in your mapfile to "DEFAULT".
Sorry if this is too trivial,
-Jukka-
Lähettäjä: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Puolesta Hugo Girard
Lähetetty: 23. maaliskuuta 2006 17:26
Vastaanottaja: MAPSERVER-USERS at LISTS.UMN.EDU
Aihe: [UMN_MAPSERVER-USERS] Setup mapserver iis
hi all, i tied what you said but it failed, my command is now :
http://localhost/MSProjects/cgi-bin/mapserv.exe?map=C:\Documents%20and%20Settings\Administrateur\Bureau\randonneurs\map\main.map&mode=map <http://localhost/MSProjects/cgi-bin/mapserv.exe?map=C:\Documents%20and%20Settings\Administrateur\Bureau\randonneurs\map\main.map&mode=map>
I can explain : I create a new web site in my IIS Manager : MSProjects
I create all the virtual directory correctly : cgi-bin, tmp, ms_tmp, chameleon
I add this line to my mapfile : CONGIG PROJ_LIB "c:\ms4w\proj\nad\"
I change the IMAGEPATH in my mapfile : IMAGEPATH "c:\ms4w\tmp\ms_tmp"
In short I followed this tutorial completely http://mapserver.gis.umn.edu/docs/howto/setupiis
If it can help, here my mapfile file :
MAP
NAME CarteSentier
IMAGETYPE PNG
SHAPEPATH "C:/Documents and Settings/Administrateur/Bureau/randonneurs/ShapeFile"
EXTENT 193557.937263 5317901.641953 379417.206051 5401384.000000
SIZE 600 450
IMAGECOLOR 255 255 255
SYMBOLSET "C:/Documents and Settings/Administrateur/Bureau/randonneurs/etc/symbols.sym"
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
END
OUTPUTFORMAT
NAME png24
DRIVER "GD/PNG"
IMAGEMODE RGBA
EXTENSION "png"
END
OUTPUTFORMAT
NAME jpeg
DRIVER "GD/JPEG"
FORMATOPTION "QUALITY=75"
MIMETYPE "image/jpeg"
IMAGEMODE RGB
EXTENSION "jpg"
END
WEB
TEMPLATE 'C:/Documents and Settings/Administrateur/Bureau/randonneurs/Templates/TempRandonneur.html'
IMAGEURL 'http://localhost/mapservertmp/'
END
REFERENCE
STATUS ON
IMAGE "C:/Documents and Settings/Administrateur/Bureau/randonneurs/Images/KeyMap.png"
SIZE 150 113
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
LEGEND
STATUS ON
TRANSPARENT ON
POSITION LL
KEYSIZE 18 12
KEYSPACING 5 5
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 150
PARTIALS TRUE
FORCE FALSE
END
END
SCALEBAR
STATUS ON
COLOR 255 255 255
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 0 0 0
UNITS KILOMETERS
INTERVALS 5
SIZE 200 5
STYLE 0
POSITION LL
LABEL
TYPE BITMAP
SIZE SMALL
OFFSET 0 0
BUFFER 0
MINDISTANCE -1
MINFEATURESIZE -1
COLOR 0 0 0
PARTIALS TRUE
FORCE FALSE
END
END
QUERYMAP
SIZE 200 150
STATUS ON
STYLE HILITE # SELECTED | NORMAL
COLOR 255 0 0
END
PROJECTION
"proj=tmerc"
"lat_0=0"
"lon_0=-70.5"
"k=0.999900"
"x_0=304800"
"y_0=0"
"ellps=GRS80"
"datum=NAD83"
"units=m"
"no_defs"
END
LAYER
NAME Hydro_poly
DATA hydrographie
STATUS ON
UNITS METERS
SIZEUNITs PIXELS
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE POLYGON
METADATA
"DESCRIPTION" "Hydro du Saguenay"
END
CLASS
NAME "Hydrographie"
STYLE
SYMBOL 0
COLOR 91 214 249
END
END
END
LAYER
NAME Sentier_line
DATA Sentiers_mtm_nad83
STATUS ON
TYPE LINE
CLASS
NAME "Sentier"
STYLE
COLOR 255 0 0
END
END
END
LAYER
NAME "Routes"
STATUS ON
DATA Routes
TYPE LINE
LABELITEM "nomComplet"
LABELMAXSCALE 40000
TOLERANCE 0
CLASS
NAME "Réseau routier"
STYLE
SYMBOL 0
COLOR 195 158 0
WIDTH 1
END
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET 0 0
BUFFER 30
COLOR 0 0 0
PARTIALS TRUE
MINDISTANCE 20000
POSITION CC
ANGLE AUTO
END
END
END
LAYER
NAME "NomMunicipalite"
STATUS ON
DATA Nom_municipalite
TYPE POINT
LABELITEM "nom"
TOLERANCE 0
CLASS
NAME "Municipalité"
SYMBOL 'circle'
SIZE 8
COLOR 0 0 0
MAXSCALE 1100000
MINSCALE 1
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET -10 -10
BUFFER 0
COLOR 0 0 0
PARTIALS FALSE
MINDISTANCE 1
END
END
END
LAYER
NAME "SentiersLoc"
STATUS ON
DATA Sentiers_Localisation
TYPE POINT
LABELITEM "Nom_du_sen"
TOLERANCE 5
CLASS
NAME "Identification des sentiers"
SYMBOL 'circle'
SIZE 10
COLOR 255 0 0
MAXSCALE 1100000
MINSCALE 100
TEMPLATE "C:/Documents and Settings/Administrateur/Bureau/randonneurs/Templates/InfoSentiers.html"
LABEL
TYPE BITMAP
SIZE MEDIUM
OFFSET -10 -10
BUFFER 0
COLOR 0 0 0
PARTIALS FALSE
MINDISTANCE 1
END
END
END
END
Thanks for the help !!!! I appreciate it !!!!!! ;)
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060324/ffaf2b59/attachment.html
