Map files for dummies?
Fawcett, David
David.Fawcett at STATE.MN.US
Fri Mar 24 14:59:36 EST 2006
Dave,
Unless you are specifying the layer name in the URL that is calling
MapServer, you will need to set the STATUS of your layer, "Bexar County"
to DEFAULT.
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Dave Nuttall
Sent: Friday, March 24, 2006 1:09 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Map files for dummies?
I have an instance of Mapserver 4.8.1 running on CentOS with
Apache 2.20, PHP 5.1.2 and Mapscript running as a DSO.
I can make/display maps where I use the canned tutorials. But
I'm failing to create map displays when I substitute shapefiles that are
of local interest.
The shapefiles in question are apparently valid, since I can
read them without any problems using "ogrinfo -al shapefile.shp".
I extract the decimal dimensions and create my own *.map file,
but all I ever get is the layer for pseudo-credits.
If someone could tweak my map file (which follows), it would be
a valuable learning experience for me.
TIA.
Dave Nuttall
San Antonio, TX
Here is my map file:
MAP
NAME BEXAR2
STATUS ON
SIZE 400 300
IMAGETYPE PNG
IMAGECOLOR 240 240 240
SHAPEPATH "/var/www/data/texas"
# the extents were pulled from the shape file with ogrinfo
EXTENT 29.114435 98.116613 29.760630 98.806552
UNITS DD
LAYER
NAME "Bexar County"
TYPE POLYGON
STATUS ON
DATA "tgr48029all"
# don't know if this projection is valid!
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "Bexar County"
OUTLINECOLOR 90 90 90
COLOR 0 255 0
END
END
# End of map layer
# This credits layer always works/displays!
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS 10 290
END
TEXT 'Made with Mapserver.
AIM to see it.'
END
CLASS
LABEL
TYPE BITMAP
POSITION CR
COLOR 0 0 0
END
END
END
# end of credits layer
END
# end of bexar2.map for Bexar County, Texas.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060324/ad1d1b25/attachment.html
