centering label inside a square
Dejan Gambin
dejan.gambin at PULA.HR
Sun Mar 26 07:53:03 EST 2006
I am trying to label a higway using a square and a highway number inside it.
I am using:
SYMBOL
NAME "square"
TYPE VECTOR
POINTS
0 0
0 0.6
1 0.6
1 0
0 0
END
FILLED TRUE
END
and the following layer definition:
LAYER
NAME "highway"
TYPE ANNOTATION
DATA "highways"
LABELITEM 'highway_number'
CLASS
EXPRESSION (length ("[highway_number]") eq 2) #this way I change the
square symbol depending of the higway number "width" (this is an example for
a square that holds higways with two numbers)
STYLE
SYMBOL 'square'
SIZE 10
COLOR 0 0 200
OUTLINECOLOR 0 0 0
END
LABEL
COLOR 255 255 255
TYPE truetype
FONT "arial"
SIZE 8
POSITION cc
END
TEMPLATE void
END # Class
# next class would have
END # Layer
Everything seems OK except that label text is not centered in the square. I
have tried changing the symbol definition, size parameters, etc. but I don't
get it correct...
Any suggestions?
thanks, dejan
