shapefile optimization for dynamic data
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Mar 27 22:16:20 EST 2006
Chris,
I would have suggested that also, but I think in the use case presented
which is an embedded system most likely excluded that as an option, but
maybe that was a poor assumption on my part. If you can install
postgres/postgis that would be ideal, otherwise I think something like I
suggested would probably work best.
Ben, let us know what works best for you.
-Steve
Chris Tweedie wrote:
> Ben, for the situation you described i would of thought pushing the GPS
> points into a database would make much more sense than trying to
> add/remake the shapefile especially at that frequency.
> Have you looked into using postgis (or any other db for that matter) as
> your datasource?
> Chris
> Quoting Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>:
>> Using shptree will not help you that much in this scenario because of
>> the frequency of updating the file. You best bet would be use multiple
>> files and a tile index that you would have to add the new files to as
>> they are created. Then you can shptree on the non-active file, but not
>> on the active file. That will probably be the best scenario. Also make
>> sure you shptree the tileindex.
>> If a shapefile does not have a qix spatial index, then mapserver
>> creates one on the fly and throws it away. If you are adding a point a
>> second the file is probably getting updated faster than you can index
>> it and then render it. Using the tileindex should really help in this
>> case also, because only the files the intersect you current display
>> window need to be opened and looked at.
>> -Steve W.
>> Ben Eisenbraun wrote:
>>> Hi-
>>> I'm building a Mapserver application with dynamic data coming in
>>> every second, and I'm not sure how to organize the shapefiles for
>>> speediest access.
>>> I'm collecting data via a GPS and a sensor that reports a data point
>>> once per second. I'm using Mapserver CGI to generate an overlay onto
>>> a map via a javascript frontend that auto-refreshes every few
>>> seconds. The application has to run on a low-power embedded hardware
>>> device (roughly a p2-266), and I'm running into performance problems
>>> once I've collected a few thousand data points. The Mapserver CGI
>>> process tends to consume all the CPU trying to render the overlays.
>>> Up to now, I've been using shpadd/dbfadd to add the data points to a
>>> single shapefile. I've tried using shptree to index the shapefile,
>>> but under my
>>> testing, it doesn't seem to speed up rendering time at all. The
>>> largest a shapefile should ever get to be is about 25,000 data
>>> points; I'm not sure if that's large or small compared to other
>>> people's data.
>>> I've thought about breaking up that single shapefile into multiple
>>> shapefiles of a given size, but I'm not sure if that would be a win
>>> for this type of situation.
>>> Given that I'm constantly updating the source shapefile, what are my
>>> options
>>> for optimizing it?
>>> Thanks for any tips or pointers.
>>> -ben
>>> simplicity is the most difficult thing to secure in this world; it is
>>> the last limit of experience and the last effort of genius.
>>> <george sand>
