Converting messages to GIS Data
Mark Howard
mhoward at AKIMEKA.COM
Tue Mar 28 19:07:03 EST 2006
I have a quick little project that requires that I convert incoming
messages (arbitrary text format with LL's) into spatial data. Pretty
easy to do - listen to a port - grab the message - stuff it into a
database (jdbc). Use an OGR ODBC connection to serve up the stuff to
mapserve. If anyone's done this in java you could save me some time if
you would be willing to share your code. Another option is to put the
data in a SDE database using the ESRI java library calls.
Anyone like to help?
TIA!!!!!!
Mark
JMEWS II/Medical Situational Awareness (MSA)
Akimeka, LLC
1305 North Holopono Street, Suite # 3
Kihei, HI 96753
(808) 442-7137
mhoward at akimeka.com
