tileindex: sequence of attributes in individual shapefiles matter
s
Eijnden, B. van den (Bart)
b.vdeijnden at AGI.RWS.MINVENW.NL
Wed Mar 29 09:10:10 EST 2006
Hi list,
today we encountered that the sequence of attributes of the individual
shapefiles which were used in a tile-index are important. In 3 out of 4
shapefiles the CLASSITEM column was the 3rd column, but in the 4th shapefile
it was the 4th column, so that one did not show up in the map ....
Apparently Mapserver fetches attribute values based on a column index? Would
it be better to fetch by name? Otherwise I think this requirement should be
documented somewhere.
Best regards,
Bart
Disclaimer
Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
hebt ontvangen, wordt u verzocht het te vernietigen en de afzender te
informeren. Wij adviseren u om bij twijfel over de juistheid of de
volledigheid van de mail contact met afzender op te nemen.
This message shall not constitute any rights or obligations.
This message is intended solely for the addressee.
If you have received this message in error, please delete it and
notify the sender immediately. When in doubt whether this message
is correct or complete, please contact the sender.
