tileindex: sequence of attributes in individual shapefiles
matter s
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed Mar 29 10:53:30 EST 2006
Hi Jeff,
no error using ogrtindex, but it's not that there is a different field,
it's just the sequence of fields which differs.
Best regards,
Bart
Jeff McKenna wrote:
> and no error was thrown when generating the index? I swear I've hit
> this same problem when one dbf had a different field, and an error was
> displayed.
> jeff
> Eijnden, B. van den (Bart) wrote:
>> Hi list,
>> today we encountered that the sequence of attributes of the individual
>> shapefiles which were used in a tile-index are important. In 3 out of 4
>> shapefiles the CLASSITEM column was the 3rd column, but in the 4th
>> shapefile
>> it was the 4th column, so that one did not show up in the map ....
>> Apparently Mapserver fetches attribute values based on a column
>> index? Would
>> it be better to fetch by name? Otherwise I think this requirement
>> should be
>> documented somewhere.
>> Best regards,
>> Bart
OSGIS, Open Source GIS
http://www.osgis.nl
