tileindex: sequence of attributes in individual shapefiles
matter s
Bart van den Eijnden (OSGIS)
bartvde at XS4ALL.NL
Wed Mar 29 12:13:48 EST 2006
Good suggestion, done:
http://bugzilla.remotesensing.org/show_bug.cgi?id=1144
Best regards,
Bart
Stephen Woodbridge wrote:
> Bart,
> Can I suggest you write a bug against ogrtindex as this is a
> requirement for mapserver to function and it save a lot of headaches
> to catch it early on.
> -Steve W.
> Bart van den Eijnden (OSGIS) wrote:
>> Hi Steve,
>> okay, good to know tile4ms checks for this sort of thing, ogrtindex
>> doesn't throw errors ...
>> Best regards,
>> Bart
>>> Hi Bart,
>>> It does fetch by name from the first file that is opened but then
>>> remembers the indexes. If you use tile4ms, this now checks for these
>>> kinds of errors and trows and error. Mapserver can open 10 of
>>> thousands of files when drawing a layer and this would add a lot of
>>> additional overhead to fetch the column numbers based on names for
>>> every file.
>>> I know it is a pain, but your should fix the data. It would not be
>>> hard to write a little perl script to read the dbf file and reorder
>>> the attributes.
>>> -Steve W
>>> Eijnden, B. van den (Bart) wrote:
>>>> Hi list,
>>>> today we encountered that the sequence of attributes of the individual
>>>> shapefiles which were used in a tile-index are important. In 3 out
>>>> of 4
>>>> shapefiles the CLASSITEM column was the 3rd column, but in the 4th
>>>> shapefile
>>>> it was the 4th column, so that one did not show up in the map ....
>>>> Apparently Mapserver fetches attribute values based on a column
>>>> index? Would
>>>> it be better to fetch by name? Otherwise I think this requirement
>>>> should be
>>>> documented somewhere.
>>>> Best regards,
>>>> Bart
>>>> Disclaimer
>>>> Aan dit bericht kunnen geen rechten worden ontleend. Dit bericht is
>>>> uitsluitend bestemd voor de geadresseerde. Als u dit bericht per abuis
>>>> hebt ontvangen, wordt u verzocht het te vernietigen en de afzender
>>>> te informeren. Wij adviseren u om bij twijfel over de juistheid of
>>>> de volledigheid van de mail contact met afzender op te nemen.
>>>> This message shall not constitute any rights or obligations.
>>>> This message is intended solely for the addressee.
>>>> If you have received this message in error, please delete it and
>>>> notify the sender immediately. When in doubt whether this message
>>>> is correct or complete, please contact the sender.
OSGIS, Open Source GIS
http://www.osgis.nl
