UTM Projection
wbr
wbr at DETEMOBIL.DE
Fri Mar 31 03:56:21 EST 2006
Hi Dirk,
Dirk Jesko schrieb:
> Hi,
> if you specify the projection within the map file explicitly (not by
> epsg code) as Transverse Mercator ("proj=tmerc") and set the false
> easting (x_0 parameter) to 32500000 (?) it should work. Something like
> this probably
> PROJECTION
> "proj=tmerc"
> "lon_0=9.0"
> "x_0=32500000" # maybe something else
> "lat_0=0"
> "y_0=0"
> "ellps=wgs84"
> "datum=wgs84"
> "units=m"
> "k_0=0.9996"
> "no_defs"
> END
it works !
> Let me know, if works.
> The other option would be to rewrite the GeoTIFF-Header using geotifcp.
> Regards,
> Dirk Jesko
Thanks,
Wolfgang Brungert
T-Mobile Deutschland GmbH
Program and Budget Management
(TRPD13-D)
Roddestr. 12
48153 Münster
Phone: +49 251 977 4142
Fax: +49 251 977 4149
email: wolfgang.brungert at t-mobile.de
PGP Fingerprint: B3F8 D368 5EEF 3873 3C4F 423C 171E F217 7CA4 3467
