Legend problem
Fawcett, David
David.Fawcett at STATE.MN.US
Mon May 1 08:29:22 EDT 2006
Dave,
Does the class in your 'dot' layer have a name?
If you don't specify a name for the class, it won't show up in the
legend.
David.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of DjwStone
Sent: Monday, May 01, 2006 4:54 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Legend problem
I've noticed the legend on my inline map is behaving oddly.
If I call up MapServer with 2 layers (boundaries + annotation) I get the
legend for their classes, as expected.
If I select a third layer which puts dots on the map generated from a
PostGIS table (as well as the original 2), the dot layer legend doesn't
appear.
Any ideas what might be going on?
The boundary (polygon) layer has STATUS ON in the map file, the
annotation and 'dot' layers have STATUS OFF.
Dave
View this message in context:
http://www.nabble.com/Legend-problem-t1535639.html#a4172218
Sent from the Mapserver - User forum at Nabble.com.
