Legend problem
Dave Stone
D.Stone at ED.AC.UK
Mon May 1 10:57:45 EDT 2006
The old brain cells are a bit sluggish today, I'm afraid. Just noticed
the layer has 2 classes, one named, the other not. I was invariably
displaying the unnamed class ( MAXSCALE=...); when I tried the named
class ( MINSCALE=...) and it showed in the legend, the penny finally
dropped.
Thanks for your help!
Dave
Fawcett, David wrote:
> Dave,
> Does the class in your 'dot' layer have a name?
> If you don't specify a name for the class, it won't show up in the
> legend.
> David.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of DjwStone
> Sent: Monday, May 01, 2006 4:54 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Legend problem
> I've noticed the legend on my inline map is behaving oddly.
> If I call up MapServer with 2 layers (boundaries + annotation) I get the
> legend for their classes, as expected.
> If I select a third layer which puts dots on the map generated from a
> PostGIS table (as well as the original 2), the dot layer legend doesn't
> appear.
> Any ideas what might be going on?
> The boundary (polygon) layer has STATUS ON in the map file, the
> annotation and 'dot' layers have STATUS OFF.
> Dave
> http://www.nabble.com/Legend-problem-t1535639.html#a4172218
> Sent from the Mapserver - User forum at Nabble.com.
