Mapserver image filename length
Szekeres Tamás
szekeres.tamas at FREEMAIL.HU
Tue May 2 05:37:40 EDT 2006
I can see a 128 byte limitation for the filename length for
swf, and the current implementation is not safe for
multithreading that may be changed in the future.
Are you using back slashes in your filename.
Do you have any additional error messages?
Could you post a code fragment to reproduce this issue?
Best Regards
Tamas Szekeres
On Tue, 2 May 2006 10:08:47 +0200, Xavier Mauclaire
<xavier.mauclaire at GEOTER.FR> wrote:
>HI
>I'm developping a mapscript web server under .net and Mono.
I generate swf
>files using ming library and i had the folowing problem
with image filename.
>the output filename prfix is defined as
>String zUnique =
>(String)pSession.SessionID+"_"+DateTime.Now.Ticks.ToString();
> which is about 60 cars long
>Under .net all works fine but under linux files are not
welle created and
>more the site get down (oups !!)
>I'd like to know if this limit est due to Mono or Mapscript
and if limit
>there is which is its value
>regards
_______________________________________________________________________________
A legjobb akciós utazások oldala, ahol most rengeteg nyeremény vár Rád:
http://ad.adverticum.net/b/cl,1,6022,99401,161631/click.prm
