Mapserver image filename length
Xavier Mauclaire
xavier.mauclaire at GEOTER.FR
Tue May 2 08:36:08 EDT 2006
Here are piece of code
Sess
HttpSessionState pSession = context.Session;
String zUnique =
(String)pSession.SessionID+"_"+DateTime.Now.Ticks.ToString();
imageObj pImg = pMap.draw();
//I'm generating swf files
String zImageName = "carto_"+zUnique+".swf";
pImg.save(@"/srv/www/tmp/"+zImageName, null);
I'm generating one swf file by layer
The first layer file is created in the tmp directory with teh good name the
others ones are created but in the site directory with a truncated filename.
After that
the site get down
regards
Xavier
-----Message d'origine-----
De : Szekeres Tamás [mailto:szekeres.tamas at freemail.hu]
Envoyé : mardi 2 mai 2006 11:38
À : xavier.mauclaire at GEOTER.FR
Cc : MAPSERVER-USERS at LISTS.UMN.EDU
Objet : Re: Mapserver image filename length
I can see a 128 byte limitation for the filename length for swf, and the
current implementation is not safe for multithreading that may be changed in
the future.
Are you using back slashes in your filename.
Do you have any additional error messages?
Could you post a code fragment to reproduce this issue?
Best Regards
Tamas Szekeres
On Tue, 2 May 2006 10:08:47 +0200, Xavier Mauclaire
<xavier.mauclaire at GEOTER.FR> wrote:
>HI
>I'm developping a mapscript web server under .net and Mono.
I generate swf
>files using ming library and i had the folowing problem
with image filename.
>the output filename prfix is defined as String zUnique =
> which is about 60 cars long
>Under .net all works fine but under linux files are not
welle created and
>more the site get down (oups !!)
>I'd like to know if this limit est due to Mono or Mapscript
and if limit
>there is which is its value
>regards
____________________________________________________________________________
___
A legjobb akciós utazások oldala, ahol most rengeteg nyeremény vár Rád:
http://ad.adverticum.net/b/cl,1,6022,99401,161631/click.prm
__________ Information NOD32 1.1516 (20060501) __________
Ce message a ete verifie par NOD32 Antivirus System.
http://www.nod32.com
