Problems showing mapInfo text layer without OGR {Scanned}
{Scanned}
Siki Zoltan
siki at AGT.BME.HU
Tue May 2 17:47:28 EDT 2006
Hi Frederico,
Tra something like this
LAYER
NAME "sample"
DATA "path/to/your/shape"
STATUS ON
TYPE ANNOTATION
LABELITEM "text_field_to_display"
LABELMAXSCALE 8001
SYMBOLSCALE 2000 # you need it for scaleable labels
CLASS
LABEL
COLOR 240 150 5
SIZE 7
POSITION CC
FONT my_font # defined in your FONTSET file
TYPE TRUETYPE
ANGLE AUTO
END
END
END
I hope this helps you
Zoltan
On Tue, 2 May 2006, Frederico Lucca wrote:
> Hello all,
> I have a mapinfo text layer and i need to view it on the map.
> I use ogr2ogr to convert to esri shape format and put in my mapfile but i
> can't see the layer.
> I have a multi-thread environment, then i don't want to use OGR, because of
> mutex.
> LAYER
> NAME TB
> TYPE annotation
> #STYLEITEM "auto"
> #CONNECTIONTYPE ogr
> #CONNECTION "/var/www/maps/TB.TAB"
> DATA "/var/www/maps/shp/TB"
> STATUS DEFAULT
> MINSCALE 1
> MAXSCALE 50000
> CLASS
> COLOR 255 0 0
> OUTLINECOLOR 171 158 137
> END
> END
> Thanks in advance.
> Fred
> "Everything under the sun is in tune
> But the sun is eclipsed by the moon"
