Problems showing mapInfo text layer without OGR {Scanned}
{Scanned}
Frederico Lucca
fredlucca at GMAIL.COM
Tue May 2 15:38:44 EDT 2006
Other information...
# ogrinfo -al TB.TAB
OGRFeature(TB):1734
Rotulo (String) =
Style = LABEL(t:"TIRADENTES",a:0.000000,s:0.000403g
,c:#ff0000,p:1,f:"Arial")
POINT (-39.302056999999998 -7.230767)
I want the "TIRADENTES" string in my map, but it's a style in mapinfo file.
Best regards,
Fred
On 5/2/06, Frederico Lucca <fredlucca at gmail.com> wrote:
> Thanks for the help, but I think the problem is that the text i have in my
> mapinfo file don't have a text field to display. The feature is a text.
> Maybe the problem is how to translate it to a shape file.
> I already try to use:
> ogr2ogr -f "ESRI Shapefile" -nlt POINT shp/TB.shp TB.TAB
> ogr2ogr -f "ESRI Shapefile" shp/TB.shp TB.TAB
> But I have always the same problem.
> Using OGR everything is ok...
> #STYLEITEM "auto"
> #CONNECTIONTYPE ogr
> #CONNECTION "/var/www/maps/TB.TAB"
> But according to Frank, I need a thread-safe environment and OGR is not
> really threadsafe.
> Thanks in advance,
> Fred
> On 5/2/06, Siki Zoltan <siki at agt.bme.hu> wrote:
> > Hi Frederico,
> > Tra something like this
> > LAYER
> > NAME "sample"
> > DATA "path/to/your/shape"
> > STATUS ON
> > TYPE ANNOTATION
> > LABELITEM "text_field_to_display"
> > LABELMAXSCALE 8001
> > SYMBOLSCALE 2000 # you need it for scaleable labels
> > CLASS
> > LABEL
> > COLOR 240 150 5
> > SIZE 7
> > POSITION CC
> > FONT my_font # defined in your FONTSET file
> > TYPE TRUETYPE
> > ANGLE AUTO
> > END
> > END
> > END
> > I hope this helps you
> > Zoltan
> > On Tue, 2 May 2006, Frederico Lucca wrote:
> > > Hello all,
> > > I have a mapinfo text layer and i need to view it on the map.
> > > I use ogr2ogr to convert to esri shape format and put in my mapfile
> > but i
> > > can't see the layer.
> > > I have a multi-thread environment, then i don't want to use OGR,
> > because of
> > > mutex.
> > > LAYER
> > > NAME TB
> > > TYPE annotation
> > > #STYLEITEM "auto"
> > > #CONNECTIONTYPE ogr
> > > DATA "/var/www/maps/shp/TB"
> > > STATUS DEFAULT
> > > MINSCALE 1
> > > MAXSCALE 50000
> > > CLASS
> > > COLOR 255 0 0
> > > OUTLINECOLOR 171 158 137
> > > END
> > > END
> > > Thanks in advance.
> > > Fred
> > > "Everything under the sun is in tune
> > > But the sun is eclipsed by the moon"
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060502/6ff5deed/attachment.html
