gdal-version.h
Blaise
bpicinbono at WORLDONLINE.FR
Tue May 2 16:07:03 EDT 2006
Le Mardi 2 Mai 2006 21:02, bessiere julien a écrit :
> Hi,
> i'm trying toi install mapserver-4.8.1
> but running "make" i have an error message :
> mapogr.cpp:142:28: erreur: gdal_version.h : Aucun fichier ou répertoire de
> ce type mapogr.cpp: In function ‘int msOGRLayerGetAutoStyle(mapObj*,
> layerObj*, classObj*, int, long int)’: mapogr.cpp:2185: attention :
> ‘oPenColor$red’ may be used uninitialized in this function mapogr.cpp:2185:
> attention : ‘oPenColor$green’ may be used uninitialized in this function
> mapogr.cpp:2185: attention : ‘oPenColor$blue’ may be used uninitialized in
> this function mapogr.cpp:2185: attention : ‘oPenColor$pen’ may be used
> uninitialized in this function make: *** [mapogr.o] Erreur 1
> and i really can't find this gdal-version.h
> i tried :
> * www.pbone.net
> * [root at localhost julien]# yum provides gdal_version.h
> but, in vain...
> thanks
> julien
Hi Julien
Gdal is over there : http://www.gdal.org/
You can try with the rpm, but the source should compile well with simple
"./configure + make + make install" sequence.
Blaise
