Compiling Mapserver on Solaris
H. Porath
porath at WEB.DE
Wed May 3 11:55:21 EDT 2006
Hi Frank,
thanks for the hint, it worked. The next step for us is to include ogr which we tried with the following configure:
./configure \
--with-gd=/usr/local/gd-2.0.33 \
--with-ogr=/usr/local/gdal-1.3.1/bin/gdal-config \
--with-gdal=/usr/local/gdal-1.3.1/bin/gdal-config
Now the make aborts with a new symbol referencing error:
ar rc libmap.a maptemplate.o mapbits.o maphash.o mapshape.o mapxbase.o mapparser.o maplexer.o maptree.o mapsearch.o mapstring.o mapsymbol.o mapfile.o maplegend.o maputil.o mapscale.o mapquery.o maplabel.o maperror.o mapprimitive.o mapproject.o mapraster.o mapsde.o mapogr.o mappostgis.o mapmygis.o maplayer.o mapresample.o mapwms.o mapwmslayer.o maporaclespatial.o mapgml.o mapprojhack.o mapthread.o mapdraw.o mapgd.o mapoutput.o mapgdal.o mapswf.o mapimagemap.o mapows.o mapwfs.o mapwfslayer.o mapcontext.o maphttp.o mapdrawgdal.o mappdf.o mapjoin.o mapgraticule.o mapcopy.o mapogcfilter.o mapogcsld.o maptime.o mapwcs.o mapcpl.o cgiutil.o maprasterquery.o mapobject.o mapgeos.o classobject.o layerobject.o mapio.o mappool.o mapsvg.o mapregex.o mappluginlayer.o epplib.o
ranlib libmap.a
gcc -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DHAVE_VSNPRINTF -DUSE_EPPL -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_OGR -DUSE_GDAL -DUSE_ICONV -DUSE_ZLIB -I/usr/local/gd-2.0.33/include -I/usr/local/gdal-1.3.1/include shp2img.c -o shp2img.o
g++ -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DHAVE_VSNPRINTF -DUSE_EPPL -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_OGR -DUSE_GDAL -DUSE_ICONV -DUSE_ZLIB -I/usr/local/gd-2.0.33/include -I/usr/local/gdal-1.3.1/include shp2img.o -L. -lmap -L/usr/local/gd-2.0.33/lib -lgd -ljpeg -lpng -lz -ljpeg -lpng -lz -ljpeg -L/usr/local/gdal-1.3.1/lib -lgdal -lc -lz -lm -o shp2img
ld: warning: global symbol `_GLOBAL_OFFSET_TABLE_' has non-global binding:
(file /usr/local/lib/libgcc_s.so.1 value=LOCL);
Undefined first referenced
symbol in file
dlsym ./libmap.a(mapcpl.o) (symbol belongs to implicit dependency /usr/lib/libdl.so.1)
dlerror ./libmap.a(mapcpl.o) (symbol belongs to implicit dependency /usr/lib/libdl.so.1)
dlopen ./libmap.a(mapcpl.o) (symbol belongs to implicit dependency /usr/lib/libdl.so.1)
ld: fatal: Symbol referencing errors. No output written to shp2img
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
Do you have an idea for this issue?
Thanks.
Holger
-----Ursprüngliche Nachricht-----
Von: Frank Warmerdam <warmerdam at pobox.com>
Gesendet: 03.05.06 15:11:06
An: porath at WEB.DE
CC: MAPSERVER-USERS at LISTS.UMN.EDU
Betreff: Re: [UMN_MAPSERVER-USERS] Compiling Mapserver on Solaris
H. Porath wrote:
> Hello community,
> we are trying to compile Mapserver 4.8.3 on Solaris 8/Sparc. We used the following configure-options:
> ./configure \
> The make aborts with the following symbol referencing error:
> ranlib libmap.a
> gcc -c -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DHAVE_VSNPRINTF -DUSE_EPPL -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_GDAL -DUSE_ICONV -DUSE_ZLIB -I/usr/local/gd-2.0.33/include -I/usr/local/gdal-1.3.1/include shp2img.c -o shp2img.o
> gcc -O2 -fPIC -Wall -DIGNORE_MISSING_DATA -DHAVE_VSNPRINTF -DUSE_EPPL -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP -DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS -DUSE_GDAL -DUSE_ICONV -DUSE_ZLIB -I/usr/local/gd-2.0.33/include -I/usr/local/gdal-1.3.1/include shp2img.o -L. -lmap -L/usr/local/gd-2.0.33/lib -lgd -ljpeg -lpng -lz -ljpeg -lpng -lz -ljpeg -L/usr/local/gdal-1.3.1/lib -lgdal -lc -lz -lm -o shp2img
> symbol in file
> endl(ostream &) ./libmap.a(mapogr.o)
> It would be nice if anyone had an idea. We are working on this for weeks now. Thanks in advance.
Holger,
The problem is that you are using gcc to link instead of g++, so no
C++ support libraries are getting linked in. On linux I believe linking
in the shared GDAL library would bring the c++ support library with it
but that appears not to be happening in your Solaris build. Perhaps
static libs ended up being used for some reason?
Try modifying "LD = gcc" to "LD = g++" in the MapServer Makefile.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
_______________________________________________________________
SMS schreiben mit WEB.DE FreeMail - einfach, schnell und
kostenguenstig. Jetzt gleich testen! http://f.web.de/?mc=021192
