PDFLIB - using default PostScript fonts
Tom Melhuish
tmelhuish at WEBINSIGHTSINC.COM
Wed May 3 06:55:37 EDT 2006
I can not get the default postscript fonts in pdflib to display in mapserver
(i.e. Times-Roman). I read the PDF Output document but dont see how to
make the link to the default PostScript fonts that the document describes. I
assume Label->Type->Times-Roman but this doesnt work. I am able to get
TrueType fonts to work by calling them through the font.list which seams to
be able to only call TrueType fonts. The TrueType fonts create a large pdf
file and I was hoping to use postscript fonts to make the file smaller.
I configured mapserver 4.8.3 as:
./configure --with-postgis=/usr/local/pgsql/bin/pg_config --with-proj --with
-wmsclient --with-jpeg=/usr/local --with-gd=/usr/local --with-gdal=/usr/loca
l/bin/gdal-config --with-php=/usr/local/include/php --with-pdf=/usr/local --
with-libwww=/usr/local --without-tiff --enable-debug --enable-force-freetype
1
I configure PDFlib-Lite-6.0.3
./configure --prefix=/usr/local
My mapfile layer is as follows:
OUTPUTFORMAT
NAME pdf
DRIVER "pdf"
MIMETYPE "application/pdf"
IMAGEMODE RGB
EXTENSION "pdf"
END
IMAGETYPE pdf
LAYER
NAME "parcel_anno"
STATUS ON
#Get data from Shapefile
DATA "parcels"
TYPE ANNOTATION
CLASSITEM "tag"
LABELITEM "tag"
LABELMAXSCALE 1500
TEMPLATE "ttt.html"
CLASS
LABEL
FONT Times-Roman
#TYPE BITMAP (I tried this but had no effect)
SIZE LARGE
POSITION CC
MINDISTANCE 150
MINFEATURESIZE 25
COLOR 0 102 0
END
END
END
Thanks -- Tom
