Error in drawning labels in SWF MULTIPLE format
Martin Krempl
amokerk at POST.CZ
Thu May 4 13:07:03 EDT 2006
Hi, I´have got problems with drawing labels in SWF MULTIPLE format. I
found that problem is in using truetype fonts, I know thate I have to
use fdb fonts to draw labels. So I defined in my font.list some fdb
font, and when I use this font to draw label there is the same result:
Internal server error.
Here are important fragments from my map file
LAYER
NAME zastavky
DATA "the_geom from zastavky"
STATUS ON
TYPE POINT
LABELITEM smer
CLASS
NAME "Zeleznice"
COLOR 0 0 0
SYMBOL 'triangle'
SIZE 10
LABEL
COLOR 0 0 0
SIZE SMALL
FONT arialfdb
TYPE TRUETYPE
END
END
END
OUTPUTFORMAT
NAME swf
DRIVER "SWF"
MIMETYPE "application/x-shockwave-flash"
EXTENSION "swf"
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
Here is my font.list
arial arial.ttf
arial-bold arialbd.ttf
verdana verdana.ttf
tnr Times_New_Roman.fdb
arialfdb Arial.fdb
fonts are in the same directory as font.list. I have some idea that
problem is, that I use incorrect fdb font set. Could you tell me, where
I found
actually correct fdb font set file, or some others ideas to fix my
problem. Thanks Martin
PS:
I´m using MapServer 4.8.1, PHP 4.3.11, WinXP or Linux.
