Error in drawning labels in SWF MULTIPLE format
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri May 5 11:31:15 EDT 2006
Martin,
I tested the latest mapserver with my test data/fonts and did generate
a valid swf with labels.
If possible I would like you to send me directly map/data/font causing
the crash and I will look into it.
Best Regards,
Martin Krempl wrote:
> Hi, I´have got problems with drawing labels in SWF MULTIPLE format. I
> found that problem is in using truetype fonts, I know thate I have to
> use fdb fonts to draw labels. So I defined in my font.list some fdb
> font, and when I use this font to draw label there is the same result:
> Internal server error.
> Here are important fragments from my map file
> LAYER
> NAME zastavky
> DATA "the_geom from zastavky"
> STATUS ON
> TYPE POINT
> LABELITEM smer
> CLASS
> NAME "Zeleznice" COLOR 0 0 0
> SYMBOL 'triangle'
> SIZE 10
> LABEL
> COLOR 0 0 0
> SIZE SMALL
> FONT arialfdb
> TYPE TRUETYPE
> END END
> END
> OUTPUTFORMAT
> NAME swf
> DRIVER "SWF"
> MIMETYPE "application/x-shockwave-flash"
> EXTENSION "swf"
> IMAGEMODE PC256
> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
> END
> Here is my font.list
> arial arial.ttf
> arial-bold arialbd.ttf
> verdana verdana.ttf
> tnr Times_New_Roman.fdb
> arialfdb Arial.fdb
> fonts are in the same directory as font.list. I have some idea that
> problem is, that I use incorrect fdb font set. Could you tell me, where
> I found
> actually correct fdb font set file, or some others ideas to fix my
> problem. Thanks Martin
> PS:
> I´m using MapServer 4.8.1, PHP 4.3.11, WinXP or Linux.
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
