Problems displaying a very large polygon
Frederico Lucca
fredlucca at GMAIL.COM
Thu May 4 19:16:03 EDT 2006
Brock,
Ok, i could try some simplification.
But I was thinking that mapserver could deal with this kind of problem.
Thanks.
Best regards,
Fred
On 5/4/06, Brock Anderson <banders at refractions.net> wrote:
> Fred,
> Can you simplify your polygon to reduce the number of points?
> I know Postgis has a simplify() function for that purpose which uses the
> Douglas-Peuker algorithm. There are probably other tools with a similar
> capability.
> Brock
> Frederico Lucca wrote:
> > Hello list,
> > I have a layer with a single polygon, but it has 131570 points. It's
> > the territory from brazil.
> > When I try to export a gif showing only a small piece, like 1/30 from
> > the total, this spends 30 seconds (attached).
> > I observe that when the coast is more irregular this is slower to
> export.
> > Other layers are very quick to export, something like 1 or 2 second.
> > How I can deal with this problem?
> > Thanks in advance.
> > Fred
> > "Everything under the sun is in tune
> > But the sun is eclipsed by the moon"
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060504/bdc7c32b/attachment.html
