Raster image doesn't show
Ed McNierney
ed at TOPOZONE.COM
Fri May 5 10:05:03 EDT 2006
D C -
The UNITS and EXTENT in your mapfile need to correspond to the units
used in the projection of your data. If they don't, then you're looking
to reproject the data and there's some extra work you need to do.
gdalinfo will tell you the units and extent in the data source's native
projection. Changing those values in the mapfile won't change the input
data, and you're simply requesting an output image that doesn't
correspond to any part of your input data, so you (correctly) get
nothing displayed.
What is it you're trying to do? Are you trying to display the image in
a different projection than the raster source image is using? If so,
what projection does the raster use and what output projection do you
want?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of d c
Sent: Friday, May 05, 2006 5:54 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Raster image doesn't show
Hello,
I just changed the EXTENT of my mapfile which was in METERS to DD.
I just wrote down the corresponding decimals which were given by
gdalinfo.
BEFORE
UNITS METERS
EXTENT -3174450 -3225675 2867175 2815950
AFTER
UNITS DD
EXTENT -131.5 -56.5 134 -52.3
nb: the map is a raster im. of antarctica
The PROBLEM now is that THE MAP DOESN'T SHOW.
I don't get an error or anything, the map just doesn't show.
Any suggestions?
Thanks in advance.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060505/6faea45e/attachment.html
