Problem displaying svg polylines
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri May 5 13:38:51 EDT 2006
Hi There,
I saw you map.svg and I think what is happening is that your contour
line is clipped at the both edges producing an svg poliline which is
"corrupted". If that is the reason, you could avoid a clipping on the
same line if you set FORMATOPTION "FULL_RESOLUTION=TRUE" in your map
file for the svg outputformat.
let me know if it works.
Best regards.
On Wed, 3 May 2006 14:07:46 +0200, almudena rueda
<almudenarueda at INICIA.ES> wrote:
>Hello all
>I've a problem with svg format, I use it to print the map. I generate the
>svg map and then I transform ir in pdf format so the user can download it
>and print it.
>When I print the lines it seams to be ok, but when a line is cut due
to the
>zoom, it is displayed with a rect line between the two last points.
>How can I do to avoid this wrong functionality?
>I'm using mapserver v4.6.0 php script under linux.
>To see the error, go to www.munisig.com, here, go to Penagos's logo
(on the
>bottom right side)
>After the display of the main map, select "Curvas de nivel" on the
left side
>and select "Llanos" in "Ir a" on the center top side. You will see the map
>of contour lines. Now if you print it, you'll see the error on the bottom
>right side of the map.
>I attach the svg map generated by mapserver.
>Thanks in advance
>Almudena
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
