Why do I get this error message when trying to access WFS?
cropwithdawn
cropwithdawn at COX.NET
Fri May 5 16:07:33 EDT 2006
Frank
I'm running MapServer on Windows 2000 Professional. I found out that
msOWSBuildURLFilename() in mapows.c adds a backslash character.
See following snippet:
#ifdef _WIN32
sprintf(pszBuf, "%s\\", pszPath);
#else
sprintf(pszBuf, "%s/", pszPath);
#endif
I think this is what's messing things up. My mapfile works fine for WMS and
the GML file mentioned in the error message is being created in the
appropriate directory.
Is this a bug? If so, what's the work around? If not, what am I doing wrong?
Thanks!
JAB
----- Original Message -----
From: "Brown, Jeff (C2MS)" <jeffrey.brown at ngc.com>
To: <cropwithdawn at cox.net>
Sent: Friday, May 05, 2006 11:12 AM
Subject: For JAB: FW: [UMN_MAPSERVER-USERS] Why do I get this error message
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank
Warmerdam
Sent: Friday, May 05, 2006 10:59 AM
To: Brown, Jeff (C2MS)
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Why do I get this error message when
Brown, Jeff (C2MS) wrote:
> I get the following error message when I try to access my WFS
resource:
> msOGRFileOpen(): OGR error. Open failed for OGR connection
> `/ms4w/tmp/ms_tmp/\7bb0d77657833c3f75a5de7149b5572f.tmp.gml'. File not
> found or unsupported format.
Jeff,
It looks like an extra "\" is getting inserted in the path somehow.
You might want to check your temporary file path in the WEB object.
Perhaps it is in there? Or perhaps you will need to drop the trailing
forward slash from there (though that might cause other problems).
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGF,
http://osgeo.org
