Projection issue in Mapscript vs Mapfile
d c
dark.peony at GMAIL.COM
Sat May 6 06:13:38 EDT 2006
Hi listers,
I want to set the following projection (which works perfectly in the
mapfile)
dynamically in Mapscript.
PROJECTION
"proj=stere"
"ellps=WGS84"
"datum=WGS84"
"lon_0=0"
"lat_0=-90"
"lat_ts=-71"
"units=m"
END
------ MapScript ----------------
$map->setProjection("proj=stere, ellps=WGS84, datum=WGS84, lon_0=0,
lat_0=-90, lat_ts=-71, units=m");
- or -
$layer->setProjection("proj=stere, ellps=WGS84, datum=WGS84, lon_0=0,
------- Error -----------------------
Fatal error: [MapServer Error]: msProcessProjection(): major axis or radius
= 0 or not given in .....php
The parameters are identical: What's the problem? Doc help on this subject
is scarce...
I've tried to add several more parameters specified on the Proj4 site, for
this projection
(x_0 = 0, y_0=0, k_0=1.0) to no avail.
Any suggestions extremely welcome,
Dan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20060506/177b0542/attachment.html
