php-Mapscript 4.8.3 breaking php.exe
Delfos, Jacob
Jacob.Delfos at MAUNSELL.COM
Sun May 7 22:36:04 EDT 2006
Ben,
Sounds like you may have run into this bug:
http://bugzilla.maptools.org/show_bug.cgi?id=1409
I think new binaries have been put on the MS4W site. These binaries have
been compiled differently from the Dmsolutions ones, so be careful you
don't mix DLL's.
Regards,
Jacob
> -----Original Message-----
> From: UMN MapServer Users List
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ben Madin
> Sent: 8 May 2006 10:19
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] php-Mapscript 4.8.3 breaking php.exe
> I have an intermittent problem where I produce a map using php-
> mapscript, , save the imagefile and the mapfile, display the map (in
> a form) and finish up the page, but although my entire page
> displays,
> the server machine (Win XP SP2 / ms4w (latest release - Apache
> 2.0.55 / php 4.4.3-dev / php-Mapscript 4.8.3)) displays an error :
> php.exe - Application Error
> The instruction at "0x7c91103c" referenced memory at "0x02660928".
> The memory could not be "written".
> Click on OK to terminate the program
> [ OK ]
> the page loading "hangs", and the server won't accept any further
> commands until I click on the OK button.
> It is intermittent, I gather it might be a memory management issue
> with php, and while I suspect this may be a php / apache problem, I
> wonder if anyone else has seen this issue. I have been using the
> latest ms4w release since the day after Howard posted it, but only
> php-mapscript since Thursday, and have only been seeing this since
> then. I have looked through php but couldn't find anything , so php-
> mapscript has to be my first enquiry.
> I couldn't find anything in the mapserver archives, but I
> rarely seem
> to be able to.
> The mapfile has a fairly long but very straightforward regex to code
> countries different colours based on a status retrieved from a
> database, and then a default string for any without a status.
> Regardless, the map is rendering properly and the html is
> displaying OK.
> I can supply the mapfile if that would help, but don't want to clog
> up the list.
> cheers
> Ben
> Ben Madin
> Remote Information Pty Ltd
> Broome WA 6725
> t/f: 08 9192 5535
> m: 0448 887 220
> ben at remoteinformation.com.au
